Question about Dyson DC21 All Floors Stowaway HEPA Bagless Canister Vacuum - Iron/Titanium/Yellow
I have a dyson dc21. All the sudden the hose is hardly suctioning up anything. If I take the canaster off, the top air hole suctions extrememly well, but when I place that canister back on, the suction is not going thru the hose and picking anything up. I have squeezed the hose, I feel no air leaking and do not feel any blockages...what could be wrong. It worked fine the other day and today, it won't pick up a piece of lint!
  • 7 Answers
SOURCE: No suction
so the red hose isn't connected to a part on the vaccum so like it is connected to the connester but not to an opening just above the beater bar, this is the only idea i can supply you with. good luck, maybe i got lucky and helped you out.
Posted on Jun 13, 2008
SOURCE: Poor Suction
I recently bought a second hand Dyson DC07. Its suction was poor. I removed all the un-clipable pipe bits and to remove any blockage but it all looked clear. The Final Sponge and hepper filter did have a lot of dust in it and the rotating brush was full of hair but nothing bad.
I eventual gave in to curiosity and removed the three screws in the top or the yellow removable dust collection tube and cyclone bit to see what was in there. The mechanism to release the flap at the bottom of the collection tube does not allow you to remove the lid completely but it does open far enough to get inside. I found the whole top section of the yellow plastic bit blocked by a big plug of compacted dust and a champagne cork. If you are willing to take the risk and have a torx 15 screwdriver handy it that part may be blocked. It did get a bit messy.
If I was going to attempt the same procedure I'd remove the dust collection unit from the vacuum cleaner as I did before, but leave the clear tube attached and the emptying flap firmly closed to reduce the mess from the dust falling out the bottom while cleaning the top part.
Posted on Nov 11, 2008
SOURCE: no suction from the bottom
Check for a clogged airway between the bottom shoe and the hose inlet. The shoe is the area around the brush when looking at the bottom of the floor unit.
Posted on May 21, 2009
tvservice306
  • 458 Answers
SOURCE: wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Posted on Nov 07, 2009
Vac Belts
  • 701 Answers
SOURCE: The roller for my dyson does not turn and it does
That means that the belt is stretched, worn or broken. You need to replace the belt. You can get replacement belts and view the manual with instructions here:
Dyson DC07 Belts and Manual
Posted on Dec 07, 2009
Dyson DC14 hose won't extend and floor unit lost suction
Sounds like the exhaust side is clogged. Remember a vacuum pulls air into the cavity, but for it to work properly it also has to be able to exhaust the same amount of air it takes in. If the exhaust is blocked it will continue to suck air inside and collapse on itself, which is why your hoses are getting shorter and harder to move. Check the exhaust system for any blockages, perhaps the hole you taped was the exhaust.
Mar 15, 2015 | Dyson Vacuums
Not much suction
Hi there, it's Jack at Dyson.
If your DC21 Motorhead doesn't seem to be picking up as well as it should be, you may need to wash the lifetime pre-filter. In normal use this should be washed at least once every 3-6 months using cold water without detergent. Allow at least 12 hours for both parts of the filter to dry completely before replacing them in your machine.
You may also want to follow the steps shown in our online Support guide to make sure the Motorhead floor tool, wand and hose are free of any obstructions: http://www.dyson.co.uk/support/dc21/dc21-motorhead/my-machine-is-not-working/does-the-brushbar-turn-with-the-power-on-dc20
If you'd like some further guidance from our experts after giving this a try, we're happy to help. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 28, 2015 | Dyson DC21 All Floors Stowaway HEPA...
Hi I have only just bought my Dyson DC27 and it works perfectly on the flat, however when I take the wand out it instantly squashes the hose flat with the suction and therefore loses a lot of suction. ...
The warm air coming from beneath the clear bin is the motor exhaust, where filtered air is expelled back into the room. It's a feature of the cleaner's design, and nothing to be concerned about.
You may find that the new cleaner's hose is rather stiff to use at first due to the powerful suction. However, you should find that it will loosen up with use. You can expedite the process by stretching the hose out to its full length whilst someone else holds the cleaner in place.
If you have any further questions about using or maintaining your DC27, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so one of our experts can provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 21, 2011 | Dyson DC21 Bagless Canister Cyclonic...
I have a Dyson dc21 ... it has low suction... never happened before approx 4 years old
try completely cleaning it out and clean the filter or get a new one. sometimes when my vaccuum has low suction theres dirt clogged in the hose or the vaccuum itself. try cleaning it out and if that doesnt work try and see if the settings are messed with (if there are different settings of course)
May 23, 2011 | Vacuums
We have a DC 21 bagless. There's suction when the hose is not attached. When the hose is attached, there's no suction. We've tried to determine if something is stuck in the hose, but without success. Is...
If you suspect the hose is blocked, I would push stiff wire through it (gently) you dont want to puncture the hose.I have had so many blocked hoses in v/cleaners ( I service them) . try blowing through it. Sound silly but why not. I have had hair grips, paper, pencils, sweets, coins etc stuck in the bend of v/cleaner pipes.
pete
Nov 22, 2010 | Dyson DC21 Bagless Canister Cyclonic...
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I just bought a used Dyson DC07. Works good but
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC21 All Floors Stowaway HEPA Bagless Canister Vacuum - Iron/Titanium/Yellow Logo
228 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
