Question about KitchenAid KBGS364PSS Grill
Need to replace the ignighters. Had a Sears repair man out. He didn't even know how to get the cover off the grill no less fix it. When we finally figured out how to get to the ignighters, I was quoted about 600.00 to to replace them. Is that for real?
    Brigadier General:
  • 4,736 Answers
For $600.00 I'll come over and replace them. But, seriously, I find it really hard to believe that all the ignitors failed at the same time. First, I would ask you, did you change the battery for the electronic ignition and install the new battery properly? If it's facing the wrong direction, it won't work. It wouldn't hurt to check the battery holder for corrosion. If you see any (you'll probably need a flashlight), A Q-Tip and some WD40 works wonders in cleaning it. Also, the spark ends of the ignitor(s) may be covered with grease and won't fire. If that's the case, a cotton ball soaked in alcohol will clean them. Check the wires to each igitor to make sure they are connected (pushed on) snugly. The same holds true for the connections of the Ignitor Module.
If all else fails and you want to repair it yourself. here's a link to the Appliance Parts Pros. They stock parts for your grill, which manufactured by Whirlpool. http://www.appliancepartspros.com/partsearch/ They have a exploded view and part numbers for what you'll need.
Hope it all works out for you and Happy Grilling!!
Posted on Apr 04, 2011
Have a kenmore 796.8031 that will not start after repairman came out to fix and left. Why will it not start?
Call their butts back there to fix it!!! They didn't put it back together right.
May 16, 2012 | Kenmore Dryers
I have a almost new grill. It suddenly will not light but only a few inches past the ignighter. It will not go all the way to start the back burner
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
I hope this helped you t0 troubleshoot and solve the problem. Happy Grilling!!
Jul 10, 2011 | Weber SPIRIT E-210 (NG)
My remote lid quit working. All lights & ignighters still work. This unit is 2yrs old, but has NEVER been used! Lid doesn't work with remote or stationary up/down switch. don't know how to test if...
Since your grill is a built-in model and hasn't been used in 2 years, I hope the grill has remained covered during that time. If not, I suspect that any inclement weather may be playing a role in this. To test the lid lift motor, you will need to track the wiring from the switch panel to the motor. Making sure all the wires are still connected and have not been damaged by small vermin. Also, I suspect if you check your owners manual, you may find that the motor has either a circuit breaker or a fuse that is designed to protect the motor and may have been tripped or blown. If the grill has remained uncovered, even the switch on the console may have suffered from water damage over the past 2 years.
It all else fails, contact the authorized Fire Magic dealer you purchased the grill from or the manufacturer, the R.H.Peterson Company, Technical Service @ 800-332-3973.
Hope this helps you to start troubleshooting the problem.
Mar 29, 2011 | Fire Magic Echelon E790i2E1P Stainless...
Dryer wonT heat, but drum turn
You need a heating element replaced. It is not hard to fix, the heating element should only cost you about $20.00 and for the labor it might cost you $45.00 for the repair man to fix it. A total of about$65.00 maybe even less.
wvrain2006
Sep 29, 2010 | Dryers
I have a Colemann 3000 grill which is in need of repair. The grill has been in storage for the past five years. The guts seem to have rusted out. I'll replace the parts, but am curious as to how best to...
Order the parts from Coleman.com or take it to Sears or grill repair person. If you do it yourself, take it apart first so you know wxactly what parts you need. I have the same grill in the same condition. I am replacing the rusted parts and expect it to look and function like new. I got mine to last a little longer by spraying the inside of the grill down with PAM in between uses after cleaning.
Oct 18, 2009 | Coleman Grill
Need advice and owner manual for Kenmore grill
Many Owner's Manual can be found online. Go to the Home page of Manage My Home and hold your mouse over the square labeled HOME in the upper left of the page. A drop-down menu will appear, choose the option Products and manuals and then enter the model information and follow the steps.If the manual is not available there, you might need to order a replacement hardcopy through your Sears Store or online through Sears. To find a parts diagram or list for your model online, go to www.Sears.com and select PARTS or go directly to www3.Sears.com
Jul 15, 2009 | Kenmore Grilling
Kenmore Model #106.52214104 Side by Side Refrigerator
Personally I'd go with the repair company - I had a bad experience with Sears - they did something similar to me and I'm not too impressed with their service standards.
Sep 27, 2007 | Kenmore 50522 / 50524 Side by Side...
Rusty Drum!
you can extend the life for a little, by painting with a rustolum paint, but not for to long, better buy a good new one, use your experience when select the new one...good luck
Aug 07, 2006 | Zanussi TC7114W Electric Dryer
KitchenAid KBGS364PSS Grill Logo
313 people viewed this question
Top KitchenAid Grilling Experts
paulcarew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
