I have a Samsung LCD TV and it won't turn on - Televison & Video
Without additional information (such as the model number) this problem could be a number of things. If the television is attempting to come on but clicking on/off continuously you most likely have bad capacitors on the main board.
You can verify this by doing the following:
1. Disconnect the power cord connecting the television to the wall (IMPORTANT).
2. Remove all of the screws on the rear cover of the television. They will most likely all be phillips head.
3. Carefully pry the rear cover off of the television.
4. Locate the power board. On Samsung LCDs it will be the board with the AC power plug built into it.
5. Visually inspect the board for bad capacitors. Capacitors look like cylindrical towers with a cross cut into the top. If the top is bulging upwards then the capacitor is bad and must be replaced.
6. Locate replacement capacitors for those that are bulged. You must use capacitors that have the same microfarad value (uf) and the same or higher voltage (V). (Samsungs frequently have bad 1000uf 25V capacitors). Your local electronics store may carry these.
7. Using solder wick, remove the bad caps from the board and install the replacements with a soldering iron. (remember to cut the leads off)
8. Put the back cover back on and plug it up. 9 times out of 10 you will end up with a working Samsung TV.
Posted on Apr 04, 2011
    Problem Solver:
  • 15 Answers
Hello! Just check your main power supply socket. If it is ok than just open your tv back cover and check the fuse. I am sure the fuse is burnt. If the fuse is also ok than you need to consult a technition. But mostly it is the problem of burning fuse
I have Samsung UN55EH6050 TV with sound but no picture
check this out..
Samsung power defect causes some TVs to fail and class action suit follows
Watch this video.. ( I did mine - three times - before I bought a LG).. its not hard.. just a little time... the local TV repair shop can install these for you..
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
watch the + and - sides when installing..
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
Sep 08, 2017 | Samsung Televison & Video
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
I got samsung tv ln32a330j1d it won"t turn on even
You have a bad power supply.
You can get get parts for this tv at www.interliquidparts.com
Aug 28, 2011 | Samsung LN32A330 32 in. LCD TV
My tv keeps clicking and won,t turn on
It is very possible that the power supply may have gone out. Which unfortunately is common on many newer tv's and other appliances. You can use a multi-tester or voltage tester to see if there is any power coming out of the power supply.
Jun 15, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
