Question about Riccar 8850 Vacuum
Replacing a belt on the Riccar 8850...I see how the brush assembly will work with the new belt. But I don't see how a new belt will turn on the small rod extending from the motor. Is there a pully missing?
  • Riccar Master
  • 1,534 Answers
There is not a pulley missing, when the belt is tight the shaft will turn the belt but when the belt loses elasticity it will slip on the shaft when being used on the carpet. Replace the n
belt at least once or twice per year.
Posted on Mar 06, 2015
Vac Belts
  • 701 Answers
SOURCE: Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Posted on Dec 15, 2009
VacuumRepair
  • 438 Answers
SOURCE: My Riccar 8850 stopped running.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
Posted on Mar 18, 2010
Testimonial: "Thanks for the information. I pressed the reset button and everything is working fine again."
SOURCE: My Riccar 8850 belt works but the roller will not spin
I see this same problem posted repeatedly here. The only solutions offered are to "change the belt". When most people state that they've changed the belt and still have the same problem the recommendation is usually "are you sure you changed the belt correctly?".
Bogus. This is a major design issue with the Riccar 8800 series vacuums. It has something to do with the roller and clutch assembly. Either people must replace these every 3-4 months, as they fail at a cost of $50+, or there is another solution and this solution is something other than "change the belt".
Posted on Mar 19, 2010
dcramer531
  • 1654 Answers
SOURCE: model 8850 riccar no suction
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
If this is ok, then there probably is still something clogged in the system, Up inside the bottom of the vacuum there is a hole where the dirt goes in to get to the bag. That's where the clog probably is. Also if If the belt is stretched, then it can't turn the brush rol under load, if you haven't chenged it in the last 6 months, then I would put a new one one. Also check the dirt inlet by the brush roll for a blockage. Last but not least, the base plate on a vacuum must fit tightly against the bottom of the vacuum for it to get good suction. this is a culprit on a lot of repairs so make sure the bottom of the vacuum is put togethere correctly and tightly.
Posted on Apr 04, 2011
rockmeister
  • 2047 Answers
SOURCE: Problem with Riccar 8850 Vacuum There
Hello there, when sparks come flying out of your vacuum cleaner it usually is as a result of messed up connections and power fluctuations.The probability of the motor needing replacement is very high as unless i examine it i cannot say for certain but one thing i can say for certain is that the entire wiring of the unit has to be inspected thoroughly because this is where the main problem would have emanated from. The unit would definitely need other components other than the motor changed this is because if the other components which have been affected dont get replaced then even a new motor will face the same problem after a relatively short period. best refer the unit to an expert to determine the extent to which the other components are affected and what other parts are damaged. Also to determine if the entire motor needs replacement or some part of the motor can still be salvaged.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Sep 08, 2011
My Riccar 8850 is very hard to push, even moreso on heavier pile carpet. Know any reason why? Also see my "more details" section.
adjust the setting on the vacuum head to pile or plush carpet
it is a simple lever that raises the hood to allow more air under it to make it easier to push
Oct 07, 2015 | Riccar 8850 Vacuum
Belt continually slips off Riccar upright vacuum
Your 8850 is an old vacuum. If a new belt does not solve the problem it may need a new rubber motor mount or metal pivot. Both parts are inexpensive and available from your Riccar dealer. If it's been a while since it's been serviced it would be wise to have it serviced by your dealer. A Riccar vacuum will last for many years but should be serviced once a year like all vacuums.
Apr 07, 2014 | Riccar 8850 Vacuum
Broken foot pedal riccar 8850
Remove the assembly that holds the foot pedal by removing the three screws after you've removed the bottom plate and brush roll. This allows you to get the nozzle housing out of the way so you can rotate the assembly holding the foot pedal from the metal pivot. Remove the e clips from the shaft and pull the shaft out of the foot pedal (be sure to look closely at the spring and how the shaft are positioned so you can be sure to install them exactly the same way you took them off. It is not a hard job but can be confusing the first time. It's not an expensive fix to have done by your Riccar dealer.
Apr 06, 2014 | Riccar 8850 Vacuum
I NEED A BELT FOR A RICCOR 8900..............................PART NUMBER A20-R2 CAN YOU TELL ME WHICH ONE I NEED.....................THANK'S CRISTA HARDIN
You seem to have two model numbers. I plugged the following into Google and got plenty of locations for Riccar belts.
Riccar 8850 Vacuum belts
You can do this and find a supplier you might want to deal with.
Sep 15, 2010 | Riccar 8850 Vacuum
My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Riccar 8850 Vacuum
No suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Dec 29, 2009 | Riccar 8850 Vacuum
Replacing belt but brush does not turn
Are you sure that you have the right size of belt? This is the correct belt:
Riccar 8850 Belt
Dec 16, 2009 | Riccar 8850 Vacuum
Riccar 8800 Belt
Dec 15, 2009 | Riccar 8850 Vacuum
How to replace Riccar Roller Brush Bristles.
On the belt end, there is a clip #59 to remove then you can take the brush roll apart, replace the brush strips and put it back together.
Jan 02, 2009 | Riccar 8850 Vacuum
Thats one of the best vacuums out there.
Take off the bottom plate and you'll probably find that the belt has either come off, broke, or completely stretched out.
If thats not the case, comment back, but I think you'll find that it is.
Good Luck
Dec 01, 2008 | Riccar 8850 Vacuum
Vacuums Logo
288 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
