Question about Whirlpool Calypso GVW9959K Top Load Washer
What LD words display on my washer mean? - Whirlpool Calypso GVW9959K Top Load Washer
    President:
  • 2,187 Answers
This means that the drain time is longer than expected. This may be caused by you drain hose bent or may have kinks or kit is blocked which may need cleaning.
Posted on Apr 04, 2011
Why does my washer wtw6200sw2 display an Ld code?
The Ld code is Long Drain. You might have a clogged hose. I had this problem once with mine. We had to empty the washer by hand and turn it on its front. Make sure you unplug it first! There is an elbow that I think was attached to the pump. We popped it off and it was clogged with dog fur (from washing dog bedding). Cleaned it out and put it back on and that took care of it. I found the diagram of the system online and suggest you look for it too - my memory isn't what it used to be - it'll tell you what to look for and where everything is. It could be the pump, too, but hopefully just a clogged hose.
Jun 07, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
What does LD mean?
LD means long drain. There is a problem with the draining part of the cycle. You might be over sudsing or the drain hose is too low. Let me know if this helps.
Oct 13, 2009 | Kenmore Elite 45986 Front Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
What does LD mean in the LED time screen? it fills for a min then stops and flashes Ld
Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Jul 28, 2009 | Kenmore Elite 45986 Front Load Washer
WHIRLPOOL CABRIO WASHER
LD means long drain and will require a drain pump replacement. The new pump is totally different from the old one so unless you are very crafty and good at figuring out puzzles, you may need to have a service company come out.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does it mean when LD shows in the display on my washer?
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Apr 03, 2009 | Kenmore Elite 20972
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
