Question about Sony PlayStation® 3 (60 GB) Console
My Playstation 3 will come on but will not display on television what would be some likely causes for this
  • 4,889 Answers
The cause of this problem is that the resolution set on your tv is not same as the output resolution of the PS3. To get over this problem just power off the PS3 then press and hold the power button infront of it for 10 seconds until you hear 3 beeps. Once it happens you will see the initial PS3 setup screen and you can just follow the on-screen instructions to set it up.
Posted on Apr 04, 2011
The usb cable on my ps3 is not working will not play on any tv in house it plays with hdmi cables
Playstation 3's will not output display information via usb, it does although have a traditional Playstation style connector port for displaying via component cable/ AV cable. To switch to this display setting without having access to an HDMI television press and hold the power button until the PS3 beeps for a second time. Pressing once it will beep but continue holding until the device beeps again and it will boot into a display "safe mode" and ask you to verify your display settings.
Oct 11, 2014 | Sony Playstation 3 (PS3) Console
Tip
Playstation 3 no display?
Have you changed from A/V to HDMI and now cannot get a display?<br /> <br /> Playstation 3 not showing video but playing sounds?<br /> <br /> Follow these very simple steps to bring your Playstation 3 back to life!<br /> <br /> <u>Step 1.</u><br /> <br /> Turn the Playstation 3 off into standby mode (red light on)<br /> <br /> <u>Step 2.</u><br /> <br /> Press and hold the power button. The console will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep<br /> <br /> <u>Step 3.</u><br /> <br /> Wait for the Playstation 3 display to initialize.<br /> <br /> Your Playstation 3 should now display properly and you can get back to your gaming!<br /> <br /> Hope this tip helps you out.
on Nov 10, 2010 | Sony Playstation 3 (PS3) Console
No display on the television
The system may have been connected with a different video type. Like hdmi, or rca. If you hold down the power button for ten seconds or so, until it beeps a few times, then let it start up, it should fix itself.
Jan 18, 2014 | Sony Playstation 3 - System - 250gb -...
When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
  1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
  3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
  4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
  7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
HDMI green screen
1-HDMI is available in several versions. The PLAYSTATION 3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PLAYSTATION 3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
The HDMI cable is not included with the PLAYSTATION 3. If you are using an HDMI to DVI converter, you may wish to remove this adaptor.
2- The resolution output (i.e., picture quality) of the PLAYSTATION 3 will depend on three factors:
The type of cable used and the inputs available on the TV or display monitor.
The maximum resolution the TV or display monitor can support. The PLAYSTATION 3 can output two types of resolution: HD and SD. Refer to the TV or display monitor's owner's manual to check which video modes are supported.
The maximum resolution programmed into the source material (movie or game). Refer to the software packaging for information on maximum resolution details or contact the publisher directly.
3- Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HMDI setup and/or equipment.
4- Disconnect any coaxial cables at the point closest to the television. Signals sent through coaxial cables may cause interference with the sound and picture outputted from the PLAYSTATION 3 which results in buzzing and humming noises from your display and speakers.
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
Hitachi 46F500 will not recognize a Playstation 3
It is my understanding that the 46F500 HD Ready only goes to 1080i and for Blu Ray you need 1080p. There are no ports for this format.
Nov 17, 2008 | Hitachi 46F500 46" Rear Projection...
High definition
Have you tried Video input #5?
Sep 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hello ive just purchased a technika television for my playstation 3 ive plugged in a hdmi cable to both the playastation and the television and i get no picture and i do not no how to tune it as it does...
Playstation 3 automatically defaults to 1080p resolution when you open the box, if your tv does not accept or display 1080p resolution what you want to do is plug it in using component cables and go into the playstation settings and lower it to 1080i then reconnect using HDMI and you should get a picture
Aug 11, 2008 | Televison & Video
Sony PlayStation® 3 (60 GB) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
