Question about Craftsman 25cc Gas Line Trimmer
Starts for a few seconds then dies then i have to pull my arm out of socket to get it to start again
  • Craftsman Master
  • 7,482 Answers
Check your fuel filter if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 07, 2011
Hi there . I'm having problems with my 1997 Opel corsa utility . It starts and idle smooth but after about 20 seconds it splutters and die , if I press the petrol it starts to splutter and die . Usually it...
I'd guess: not enough fuel flow. could be a fuel filter, fuel pump, fuel pump relay, fuel pressure regulator. No check engine codes? I would think there should be some that would help diagnose.
Mar 04, 2015 | Opel Corsa Cars & Trucks
Craftsman 22" self propelled platinum series lawnmower died while pushing it. wont restart. ????
A good place to start is taking the air filter off. Then try stArtingvit again. Often a dirty air filter will not allow a mower to stay running. If that does not help. Remove the cover under the carburetor looking for dirt in the cover. Also well the cover is off remover the small pin that holds the float in place. Pull the neddle valve out cleaning it and the other parts with a carburetor cleaner then reassemble
Jul 21, 2014 | Briggs & Stratton Garden
Yz 426 while riding it i went to park it thought it was out of gear and let out on the clutch and it died went to start it back up and the kick start seemed to b stuck so i rocked it back and forth fi
How does the compression feel now that you have it cranking over again. Without the decompression lever pulled in it should be next to impossible to kick it over. also, is there any noise coming from the engine (knocking, etc.) when you got it to start again.
May 05, 2014 | 2003 Yamaha YZ 125
Why is the cylinder flooding with gas
i promise u its the carb buy the whole unit
Nov 01, 2013 | kawasaki KX 250 Motorcycles
Difficult starting in warm weather
Check the vacuum hose attached to the fuel pressure regulator under the hood next to your intake pull it off and see if any fuel is present, if there is replace regulator.you may have to tap hose with your finger to get any fuel out or start vehicle run until hot then shut off and recheck if no fuel present in vacuum line let me know and we can try something else.
Aug 23, 2009 | 1999 GMC Sierra
86 bmw L7
I think your problem might be your fuel relay which is situated next to the fuse box in the engine compartment.
Jul 13, 2008 | 1986 BMW L7
Runs for just a few seconds then dies
sounds like a distrubuter cap/rotor arm fault more info required
Jul 06, 2008 | 1997 Jeep Cherokee Country
Craftsman 25cc Gas Line Trimmer Logo
59 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
