Question about Heath Zenith Electrical Supplies
When door bell is pushed the chime unit playes through all of the songs instead of just one.
The unit is receiving electricity so low-voltage transformer and button are working correctly.
Only suspect left is door chime itself.
Check that voltage of transformer matches voltage of chime.
Use cheap multimeter from home center and check voltage at chime, or check transformer.
Doorbell transformers are usually located in basement or garage or attic, and most are hardwired into octagon box.
There are no replacement parts for door chimes.
Buy new one, or contact seller for refund if this is new chime.
Posted on Apr 08, 2011
Why does my chime ring when next door has visitors
You're using the same channel. Change the channel the bell-push and the bell work on, by following the instructions that came with the bell and bell-push units.
Mar 21, 2015 | Cars & Trucks
I had to replace the doorbell button, now the doorbell only buzzes instead of chimeing. I have tried three different buttons and they all give the same result. Whats wrong?
This has to be a setting of dip switches that got changed somehow on the chiming unit. Open that up and check the settings.
Feb 22, 2015 | Home Security
How do I set the chimes
Chimes are usually set from inside the bell-push, so that you can have multiple bell pushes and different chimes for each one.
Feb 13, 2015 | Home Security
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
Evo 46400PL Ed3 wireless door chime, no connection between the bell push and the chime unit.
Maybe the batteries are emty, is that not the problem then lay down the bell push in your living room for 1 day, the companents can be a little wet, you can't see that ( they look to be dry) I had this problem too and it works.
Jun 26, 2011 | Vacuums
We purchased the Heath/Zenith TR-0081-BX Wired Door Bell. However, we can not get the chime to continuously play without holding the bell down for expended period of time. How can we fix this? I lost the...
There is a little "diode" that should have been provided as part of the unit...it's a little wire with a B-B-sized circuit in the middle that has to be connected to the push-button at the door. This "extends" the circuit from the button to the chime unit for the full 8-notes. Hopefully you still have that part (I just about threw out mine before I read the instruction manual thoroughly. My diode just "shorted" after I power-washed my house...and I am in search of that particular part. I contacted Heath Zenith...hopefully they will give me a solution on how to get only that part. In any case, you need that diode to get the chime to play correctly.
Mar 16, 2011 | Garden
I have a desa TR-0081-BX wired door bell. When you push the button it only gives a short chime . If you hold the button down it goes thru a 8 note chime what can be done to fix this. There is only one...
Mar 15, 2011 | Desa International White Wireless Plug In...
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
I have two door chimes with the same frequemcy, but different codes. I need to place the chimes in different rooms as I am hard of hearing. How do I match both codes so that they ring at the same time when...
You need to change the pin configuration in both the remote buttons to match each other, (as well as the bell unit) just make sure they match on both bell units. Also, since one works just use that configuration and change the button pin configuration that does not work to the button that does on the other button unit.
Mar 03, 2009 | Desa International White Wireless Plug In...
Electrical Supplies Logo
258 people viewed this question
Top Heath Zenith Electrical Supplies Experts
lakeareaserv
Gene Haynes
George Balanchine
George Balanchine
Level 1 Expert
Are you a Heath Zenith Electrical Supply Expert? Answer questions, earn points and help others
