Question about Oki Electric Industry Okidata C5550n MFP Fax Machine Duplex Unit
Oki C5550 MFP display reads "Failed to Detect
SOURCE: My Oki B4545 MFP alarm always on
Solution provided by printer manufacturer tech support which worked for me.
1. Open all doors (front & back)
2. Remove tonner
3. Turn off power
4. After 20 secs turn on power
5. Close back door
6. Insert toner
7. Close front door
Fixed now!
Posted on Jul 02, 2009
don_farr
  • 1018 Answers
SOURCE: REPLACED OKI C33OO'S CYAN TONER CARTRIDGE AND
Are you using a third party toner cartridge or a refilled cartridge?
If you are, DON'T!
Don
Posted on Jan 29, 2010
omerboo
  • 424 Answers
SOURCE: following instalation of driver when I try to
Driver download link: Oki B2400N Printer Driver
Posted on Feb 02, 2010
  • 76 Answers
SOURCE: How can I restore factory
tokkummaa fi walabummaa sagalee bilisummaa oromoo
Posted on Jun 23, 2011
  • 35 Answers
SOURCE: Emty error with new toner. Oki B410
What a usless "solution"...Do you have something that can accually work?
There is a procedure that will solve this issue. I have a new toner inserted and it keeps crying that the toner is empty...I have taken in out and put it back in, Now how do I reset the **** thing?
Posted on Jan 19, 2012
Oki c5550 INCOMPATIBLE YELLOW
Are you using factory or aftermarket toner?
Jan 07, 2014 | Oki Electric Industry Okidata C5550n MFP...
Oki c5550 mfp
i have the same problem with my magenta drum unit on my oki c5550 the screen says missing M drum unit and the other errors i am getting are incompatible toner C,Y,K. how do i fix these
Aug 08, 2013 | Office Equipment & Supplies
Oki C5510 'Unable to detect printer'
If you have all the led's lit and they are not flashing it means the printer is in download mode. In other words its waiting for you to download new firmware. Look at OKI's site and find the firmware and follow the instructions. That's why you cant install drivers because the printer no longer knows what it is!
Jun 17, 2017 | OKI C5510 MFP All-In-One Led Printer
Failed to get printer information - Check printer
the the usb cable connecting your printer to your pc
Oct 22, 2011 | OKI Electric Industry C5550 Laser Printer
I NEED TO INSTAL OKI B2540 MFP PRINTER ON MY
You can go here
http://www.oki.co.uk/support/printer-drivers/index.aspx
May 18, 2010 | OKI B2540 MFP Printer
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
I´ve got a message on my oki C5510 mfp printer "Failed to get printer information - Check printer". I´ve checked all cables and everything is ok. The toner light and exclamation light staying lit...
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
Nov 08, 2009 | OKI C5510 MFP All-In-One Led Printer
2. Remove tonner
3. Turn off power
5. Close back door
6. Insert toner
7. Close front door
Fixed now!
Jan 25, 2009 | Oki Electric Industry Oki - B4545 MFP...
Oki Electric Industry Okidata C5550n MFP Fax Machine Duplex Unit Logo
324 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Victorman
Victorman
Tony
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
