Question about DFI CM33-TL mATX VIA 8601T/686B VID/LAN/SND Socket370 Mainboard (MBDFICM33T) Motherboard
Need to increase ram but don't know how to find out how much board to support or what type.
Www.crucial.com for scanner tool that tells you what type and how much supported by your board.
Posted on Apr 04, 2011
  • DFI Master
  • 27,725 Answers
Accessories included: i/o shield and cables only- no manuals or cdDFI CM33-TL/G Socket 370 Motherboard Intel Pentium III/ Celeron Onboard Video Audio IDE 3 PCI Micro ATX Motherboard Used Retail-MFG DFI Part:CM33-TL/G
2 DIMM sockets
Supports up to 1GB unbuffered DIMMs
Supports PC100 and PC133 SDRAMs BIOS
2 DIMM sockets
Supports PC100 and PC133 SDRAMs BIOS 2 DIMM sockets
Supports PC100 and PC133 SDRAMs BIOS 2 DIMM Sockets
Supports up to 1 GB of unbuffered dimms
supports Pc 100 and Pc 133 SDrams
Testimonial: "Thank you for your help."
  • 64 Answers
The configuration of system you are using and what you need it will determine the ram you will need.but with the number of slot on the board.if it has two slot know that it can be upgraded maximally to 4gb
Posted on Apr 05, 2011
What type of RAM is compatible for my desktop pc for increasing speed ?
Your motherboard can support up to 8 Gb of ram, of type DDR2 667 MHz or 800 MHz. In practice 667 would do I believe as the performance difference is not great in practice. The board has 2 DIMM sockets for this.
It depends somewhat on your OS and what you want to do. I'd try 4 Gb first. Bear in mind that added ram doesn't actually speed the computer as such, only a faster CPU does that, but it will allow more windows to be kept open, and cut down on data swapping to virual memory on the hard drive.
Jun 05, 2016 | Intel Computers & Internet
I need to know if the CPU speed can be increased to 1GHz or over and that I have put in 2 memory modules of 128MB onto it but only 128MB appears on the System Properties. Irvin.
You are confusing 2 things, CPU speed and Memory or Ram speed.
To keep things straight forward, cpu speed can only be increased by replacing it with a faster cpu.
Ram, as you can see, can be increased by adding faster ram modules.
Go to either of these websites:-
http://www.orcalogic.co.uk/asp/default.asp
http://www.crucial.com/uk/
Enter *********** board details or request they scan your computer. Check all the information offered, they will tell you what type and how much ram your motherboard can use.
If you can't increase your ram speed to more that 1Gb, I would suggest it time to invest in a new motherboard/PC rather than spending more on RAM.
There can be a whole load of reason why your second stick of ram doesn't work.
1) it could be broken.
2) It could be the wrong type.
3) You may need to update your Bios to accommodate it. Though this is very unusual.
Jul 28, 2010 | Intel Motherboard
Increase pc speed
increasing ram depends on the model of the mother board and supporting capcity, how ever you can increase ram virtually.
this may increase your pc speed
please vistit the weblink to know how to create virtual ram http://www.aumha.org/win5/a/xpvm.php
Mar 25, 2010 | Computers & Internet
Need to increase the ram on the VGA Card
My friend you can add RAM on your VGA by purchasing another Higher Video card  RAM. you can buy 512mb (265 - 512 bit) VGA Card to increase your VGA RAM.
Jun 18, 2009 | ASUS P4P800-X Motherboard
Need to buy a new Mother Board?need some help
Now a days every motherboard is come with PCI-Express Slot and this mothrboard can also handle more than 3.0Ghz CPU and it support DDR2 RAM which is faster than DDR1 RAM.
High FSB and high storage of DDR2 RAM will increase your computer performace.
DDR2 RAM FSB is depend on your motherboard choice. Because your motherboard should be able to support your RAM FSB rate.
Mar 05, 2009 | Intel Motherboard
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
I have intel pentium 3 with 128 ram. how can i increase ram memor
To upgrade your RAM you would need to know what type of RAM your motherboard supports. Once you have this info you can then check online who sells the RAM modules. Once you make your purchase you then can remove the old modules, replace with the new modules & reboot. Hope this helps & please remember to rate my answer. Thanks.
Feb 02, 2009 | Intel Pentium 3 933 (38l4460)
How can I convert 1 GB Ram into Mother Board 810 E?
YAS IS GOOD YOU CAN UPGRADE YOUR MEMMORY TI 1GB ALL YOU NEED TO DO IS GET THE EXACT TYPE OF WHAT YOUR MOTERBOARD IS USING eg IF YOUR MOTHERBOARD IS USING DD RAM GET 1GB DD RAM IF IT SD RAM YOUR BOARD USES THEN GET SD RAM. IT GONNA BE FINE WHEN YOU UPGRADE IT WILL PARFECT YOUR PC PERFORMANCE.
Nov 20, 2008 | Intel Motherboard
System wont show memeory upgrade
thing you need to know:
  • how much ram can the board take (you can't put more in)
  • the type of ram (sod,sdram,ddr,ddr2) speed is less importantas it will drop back to the slowest chip.
  • look in the motherboard manual to find out
  • search internet if you do not have the manual
  • static electricity can kill electronic compomants so ensure you have earthed yourself before going into the box or handling the chips (this is a bit late but educational)
sometimes you need to go into the bios (change nothing but "save on exit) the system should see the new ram
good luck
Terry
Mar 11, 2008 | Computers & Internet
DFI CM33-TL mATX VIA 8601T/686B VID/LAN/SND Socket370 Mainboard (MBDFICM33T) Motherboard Logo
151 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Steve Frost
Steve Frost
jason
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
