Question about Samsung P241
What dvd laser lens cleaner should I use for my Samsung p241 dvd/cd player?
  • Anonymous Mar 25, 2014
    Can i use a CD laser lens cleaner to clean my DVD player
  • 4,889 Answers
You can use any branded DVD-lens cleaner. I recommend Sony. It is just like a normal DVD except that brushes will pop out to clean the lens when you play it. After the cleaning is complete the sample video file on the DVD will be played indicating that it has been cleaned. Otherwise clean again.
Posted on Apr 04, 2011
Open dvd coverto clean laser
No need. There are lens cleaners attached to a blank CD that will do the job without damaging the lens. They are inexpensive. Just google dvd plater lens cleaners.
Feb 24, 2015 | Samsung DVD-V8600 DVD Player/VCR
Boss Audio System Model #BV8966B - will not play DVD or CD's anymore & keeps saying "No Disc"
Some DVD players cant read some DVD s and
then it shows either "loading" or " no disc"..
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Some DVD players are fine at the beginning but after some time later,it begins to have some problems as you have..This is mainly due to LASER eye problems..
Just in case,quick remedy ,
pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 11, 2011 | BOSS AUDIO SYSTEMS BV8966B Car Video...
Most times (90% or more) I input a DVD, the TV screen says Loading, and seems to be processing the DVD loading procedure, but then doesn't play the DVD -- it stays stuck on the Loading sequence. Any...
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Thanks
Jul 10, 2011 | Samsung DVD-V4600 DVD Player/VCR
WONT READ ANY DISC
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Mar 12, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
Samsung dvd p145 no disk
Good luck.
Feb 03, 2011 | Samsung DVD-P145 DVD Player
Samsung HT Q20 dvd player saying No DISK
1. Try cleaning the drive laser lens with a CD lens cleaner.
2. You need to check servo parts, spindle motor and pick up flat cable.
3. Clean laser lens manually.
Success!
Oct 25, 2009 | Samsung HT-Q20 Theater System
Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray: Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
Feb 08, 2009 | Samsung BD-P1400 Blu-Ray Player
DVD player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Dec 30, 2007 | Samsung DVD-V3500 DVD Player/VCR
Used lens laser lens cleaner & now player won't play.
You can open the dvd and try to clean it manualy.open the dvd so you can see the lazer.take a normal earbud and wet it with normal methylated spirits and clean the lazer gently with that.the lazer cleaners hardly ever work 100%.Just remember not to push to hard on the lazer or you will brake it.gently clean and wait for lazer to dry and try again.
Feb 19, 2007 | Samsung HT-WP38 System
Samsung P241 Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
