Hi,Repacking a Campy 8-speed cassette hub. Have a challenging time getting the rachetting mechanism (dogs and springs on the axle) back into the hub shell even with the Campy-supplied clip. I can load the axle assembly with the keeper clip installed but then have difficulty getting the axle all the way back in with the rachet seated in the hub shell. Is there a technique for reinstalling the rachet assembly into the hub shell?Thanks,
SOURCE: agitator problems
sounds like you have some bad adgetator dogs
they are plastic and they sit inside the white adgetator . take that off and you will see four of them. usually you need to remove the fabric dispenser first to take the bolt out of the adgetator out.
SOURCE: unable to get body mount bolts out to install nerf bars
I ran into the same problem with my running boards. They have a wing nut inside the frame. The only way I got them off was to loosen them so much and then jump on the running boards. But I did shove a screwdriver into the hole to stop the wing nut from turning. The other one I had a friend go at it with a pneumatic socket.
SOURCE: replacing the front axle on a 93 subaru legacy
When I replace the axle halves, I run the Nut off till it is level with the shaft end. THen take a piece of wood and set it across the shaft and hit the wood with a hammer. Usually only takes one or two hits and pops right out.Then I remove the nut and finish removal . Hope this helps, Good luck and have a great day.
SOURCE: front derailluer casset capacity
I know the Shimano Mega9 front and rear derailleurs work with 8 speed drivetrains, provided you are using the correct shifters.
