Question about Simmons Mattress Matino - Natural Maple Crib
I bought a crib from my neighbor. When we were setting it up the plastic piece on the bottom of the drop down side broke. I see there have been recalls on this crib. # 011643 02-267. Simmons Little Folks. Were can I get a new side? Sheila Mewes
  • 10865 Answers
SOURCE: I have a simmons little folks crib that has a
If you have the pieces of this plastic guide you can go to the hardware store and buy some epoxy [glue] designed for plastic. This will do the job for you.
Posted on Apr 20, 2009
SOURCE: Simmons crib with no model number how do I find it?
Hi swpw123
Did you ever find out how to identify your crib? I have the same issue and need to find out if it was recalled.
Thanks
John
Posted on Jul 10, 2009
Mr_Alejo
SOURCE: Instructions for Little Folks Simmons crib
Geocities is closing down their free webhosting. Simmons crib assembly guide is now available at: http://humm.110mb.com/ under free downloads.
Posted on Jul 19, 2009
jyackle5
  • 8197 Answers
SOURCE: I am looking for replacement parts on both sides
You can get any part for a crib on link below.
http://www.productsamerica.com/
Please rate 4 thumbs for free answer.
Posted on Feb 22, 2010
SOURCE: Simmons Crib N More
No, the Simmons recall affects cribs built in 1998, 1999, and 2000. The '02' after the Model number indicates yours was built in 2002. More information on the recall can be found:
http://www.cpsc.gov/cpscpub/prerel/prhtml01/01087.html
Posted on Mar 30, 2010
How to I take apart the drop down side of this crib. I had it installed and can't figure it out
This is tricky but I have put it together and taken it apart countless times (3 kids, 2 houses and everyone switching rooms). All of the screws keeping the crib together need to be as loose as possible without the crib coming apart. I found it easiest to have someone help so they can help hold the crib. It's important not to pull the drop side apart as it will break the plastic slides (I've done this and had to replace them). Have your helper hold one side of the drop crib right against the side piece of the crib and slide the drop side down to detach it from the side your helper isn't on. once this side is detached do the same for the opposite side. On the crib side that attaches to the drop side is a "screw" that slides down the plastic slide and a "peg" at the bottom. I always get the peg out of the track and then you can slide the screw all the way down the slide to get it out.
Jan 04, 2011 | Cara Mia Louise Crib
Where can I buy a crib piece ?
This crib has been recalled by the CPSC. don't use it. return it to where you bought it from asap. deaths have been rellated to that problem.
Feb 02, 2009 | Baby Gear
A piece broke
I just purchased this crib from craiglist for my daughter and future grandson. We broke the plastic track assembly on the lower left front. I just now called the customer service number and they are sending me the complete assembly and when I told her it had one stripped out bolt, she is including a complete hardware package. Didn't cost me one penny! Now that is true customer service!!!!! This is for the 3 in 1 sleigh crib, Model No. DASE5009. The customer service number is 800-295-1980. Their hours are 8am - 5pm est M-F. Hope this helps!
Jan 24, 2009 | Dorel Alexander
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Delta Luv Dutchess 2 in 1 crib
The front rail(drop rail) has a little plastic piece attached to it that reads "push".  This will be on the bottom.
Sep 01, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Plastic piece to lower side rial broke
If you have one side piece that works, I would like to buy it from you. Email bluewriter24@yahoo.com Thanks.
Jul 05, 2008 | Childesigns Bellmont Crib
The Dorel 3-1 convertible crib model # WM1633
Do not use this crib. This crib broke and caused my infant son of six months to get caught. He passed away on October 16th because of getting caught in this crib. I am trying to getting this crib recalled. Please Please do not use drop down cribs. They are entrappment devices for infants. 3 infants including my son have died in 2008 due to drop down side cribs. Please for your babies sake, take this crib back.
Jun 22, 2008 | Dorel Alexander
RITA BELLA CRIBS
I have a similar crib by Rita Bella. This is what worked for me.
1. Remove drawer.
2. Face crib's drop-side.
3. On left side of crib (based on you facing the drop-side) locate two allen head screws close to you. Unscrew them. A piece of wood in the front will drop. This is normal.
4. Push left side of crib outward (about 1/4") until you can see the metal pin that controls the locking function of the drop-side. It is near the bottom.
5. Pull out the bottom part of the drop-side so it's not in the plastic groove area anymore. This should get the right side out as well.
6. Tilt the drop-side -- the bottom part should swing toward you. When it is completely tilted, you will see the wooden groove in the side of the crib, and you can then remove the drop-side pretty easily.
7. Replace the screws. You may need an extra pair of hands to get all the parts in place.
8. Replace the drawer.
Feb 29, 2008 | Sorelle Rita Bella 15936 Crib
Childesigns Ravello Crib
Try you local hardware store. ACE Hardware or a True Value.
If you think that the parts are repairable you might ask the hardware folks for a glue that will bond that material to itself. Plastic Welder brand glue usually works well for this.
Jan 21, 2008 | Childesigns Ravello Crib
Simmons Mattress Matino - Natural Maple Crib Logo
63 people viewed this question
Top Simmons Mattress Baby Gear Experts
Stan Skaggs
Stan Skaggs
Glen Weitzdoerfer
Tom Chichester
Are you a Simmons Mattress Baby Gear Expert? Answer questions, earn points and help others
