Question about Lexmark X6150 All-In-One InkJet Printer
I was printing and everything was fine. Now, I hit start to copy an item, printer waits about 30 seconds, and shoots out a blank paper. I know I was low on ink, so I replaced the cartridge. It prints the test paper, but won't copy.
  • Official Brand Answer
  • 3,344 Answers
You printer probably needs to be reset. First, remove both cartridges from the printer. Unplug the power adapter from the back of your printer(small black box behind your printer where the power cord is attached)
(model shown may not be your printer, however, the steps are the same)
Wait for at 10 seconds before reinserting the power adapter back into the printer. When the printer turns on and looks for the cartridges, reinsert both cartridges. Let it print the test paper again. Then try to print your document again to check if it's working now.
Posted on May 03, 2011
Hp deskjet F380 is not copying.
Hello, it seems that this is a common issue with the HP F380.
Try a hard re-boot of the printer. power off the printer and hold the power off button for about 30 seconds, release and wait another 30 seconds. Power on the printer and see if it will copy.
if that does not work, disconnect from the PC, and use the copy button.
Please let me know what happens.
Jul 29, 2017 | HP Office Equipment & Supplies
How do I get my HP OfficeJet Pro 8725 printer to spit out the printed paper without force and an extra sheet?
Have the memory inside the printer tested. Add as much printer memory as you can to the printer to speed it up.
Mar 16, 2017 | HP OfficeJet Office Equipment & Supplies
My Epson NX300 prints just fine from anything on the computer screen but, when I try to print a copy from a copy in the printer/scanner tray the paper from the supply rack drops about 4 inches like its...
Connect the scanner to an old USB HUB, and it will work. It stops when you connect to a new USB connection direct in a new PC. Done it. I worked with a 2 port USB HUB. Was posted someplase but I cant remember where. Magnar Vereide Datainstituttet.no
Oct 31, 2013 | Epson Stylus NX300 All-In-One InkJet...
My Dell 3115cn MFP prints 3 blank pages between prints or copies if I print more than 1 copy how do I fix this? What is causing it?
I will do first a full printer cleaning, that mean take off all dust and anything can that can be inside the printer (ex.bugs and dirt accumulation).
Second try to locate the printer rollers and check if they are in good condition.Printer rollers need to be in good condition because those are the parts that move the paper inside the printer.
Also when you feed the papers into the feeder make sure you air the paper so they don,t stick together.
May 07, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Brother MFC prints blank pages
Try disconnecting power completely, not just turning off. Wait a few minutes and reconnect to power
Also, your print queue may be full with failed attempts at printing. The printer becomes confused and does not know what to print next. You should be able to flush the queue at the computer, but the complete disconnect and reconnect may accomplish this
Sep 04, 2012 | Brother MFC-790CW Multifunction Printer
No printing, just blank papers shooting out
First verify that the printer is working by printing a configuration page from the printer itself. If it prints fine, uninstall and reinstall the printer with the latest driver from HP.
If the printer will not print an internal config page, replace the ink cartridges.
Jun 22, 2009 | HP Photosmart C7280 Printer
Kodak ESP-3 Printer Red Flashing Light
Couple of things.
1. Look inside the printer by the print head. On one side you should see a felt pad of some sort. Make sure this has not come loose. If it has, it can block the path of the print head and will read paper jam. I have seen this mostly with the ESP 5, but I suppose the same could happen with the 3.
2. This way is kind of long but will clear a lot of problems. Open the top of the printer and remove both cartridges and the print head. Unplug the power supply and close the printer. Wait about 30 seconds. Now plug the power back in and wait until the printer stops moving inside. Open the printer and instal just the print head. Unplug and wait 30 seconds. Repeat this procedure with installing the black, then the color. Make sure you unplug for 30 seconds and wait for the internal parts to stop moving between each step. his should fix everything. It has worked for me several times. These really are a decent printer, just a little glitchy sometimes.
3. Make sure a paper has not gotten wadded up and is hidden inside to the left or right of the print head. I have seen this twice in the ESP 3.
Hope this helps.
Apr 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My pc brother mfc7420 copy but keep printing blank paper
shut the machine down, remove the ac plug from the machine and take the printer cables out of the cpu. now waite 20 min and reinstall everything, this is a starting point. let me know and  i wll get back to u we are a brother service center
Dec 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
Just started printing blank pages
you may need to prime the new cartridge by "charging it" if you go to printers/faxes menu then select "printing preferences" and clcik on the maintenance tab you should have the option to do this also to reset to default settings.
Jan 08, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Blank copies
Thanks Guest with Best Solultion! OMG! I have had my machine printing blank for over a month now and reading stuff and trying to find a solution. Until finally today I found this page. I read your solution and hit the front like u said for several times and nothing. Finally, after the third try WALA...IT WORKED!!! Thanks again. If anyone has this same problem try this because it really works! Eventhough this is such a strange problem for such an expensive machine.
Oct 04, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
Lexmark X6150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
