Question about RTO Plumbing
Basement watchdog charger does not stop charging. Big Dog 3500 GPM
  • larry beining Apr 05, 2011
    What repair part is usually needed for the charger if I prove out the battery is ok?
  • larry beining Apr 07, 2011
    I asked you earlier that if I proved it was the charger what component needs changed?
  • RTO Master
  • 43,501 Answers
The charger is controlled by an electronic controller...that would be the most likely problem and the reason for it not shutting down IF the battery is good.
My first reaction is that the battery will prove to be the problem though.
If you need more info and testing the best place to call will be to call the service department at 1-800-991-0466
heatman101
Posted on Apr 06, 2011
  • 12,061 Answers
Hi, whenever a charger will not stop charging, it is usually because it is not "Seeing" the correct charged "Internal Resistance".
This can be for one of two reasons, One, the Battery is faulty, and even though it may appear to charge nevertheless there is an internal problem with the battery. Two, The charger is faulty.
How to tell, the ONLY way is by substitution, with a known good one. Either replace the Charger or Battery and see if the "Problem" follows.
Usually if the charger isn't faulty, then most times it is the battery itself, the internal resistance increases as it ages. IF a wet cell, it may respond to battery rejuvenation, potassium permanganate, Condies crystals, KNOH8 a teaspoon per cell is a great battery rejuvenater.
Posted on Apr 04, 2011
How to hard reset digital watchdog DVR
Jason,
I found the following for DVR Vmax Flex: Reset procedure is as follows, Press and hold the OK button on the remote for 45 seconds, it will beep many times, a screen will pop up and ask you to reset, select YES. The reset will default it to factory, which is No Password at all. If this is not the info you're after, you can choose a method to contact Digital Watch Dog shown on their webpage:
http://digital-watchdog.com/
Apr 07, 2014 | Digital Watchdog Televison & Video
Vostro 3500 won't turn on and charger light is flashing
How old is your laptop? if it is over 5-6 months it could be because of a faulty battery. You may want to upgrade or change your battery.
Apr 10, 2013 | Dell Vostro Computers & Internet
Watchdog sump pump want stop beeping
if you have a home entertainment system just turn it on and up kidding the sump pump for our home is always running i have never heard in beep just whines constantly Is the pump still working? I have had pumps go bad before but they never beeped they didn't do anything after burning up the motor i wonder if its a battery maybe 9v
Sep 10, 2012 | RTO Basement Watchdog Sump Pump
Battery has liquid on top
The battery is charging with trickle charger. The liquid could be just water from condensation from the recharging process. If the charging is too vigorous, then it can also be sulfuric acid, so rubber gloves are in order. Clean up liquid with gloves on and paper towels. Once dry carefully remove caps and check water level. refill battery with distilled water to top of cell. Check water level at least twice a year. Wear safety glasses too.
Oct 03, 2010 | RTO Basement Watchdog Sump Pump
The alarm continues to sound. The red light for battery is on. I did add water and it went off for a very short time m, but then continued. I added more water, definitely full, and it continues to...
(Batteries may be substituted by using a deep cycle marine battery with the same specifications as described above, but the battery fluid sensor option will not function. Simply connect the battery fluid sensor to the positive terminal of the battery to disarm battery fluid sensor alarm).
Aug 05, 2010 | RTO Basement Watchdog Sump Pump
Phone won't charge. Dog destroyed charger where it links to phone. bought new universal charger but now am thinking the receiver part of the phone is damaged cuz the new charger fits...loosely...but...
Your dog may have broken a wire inside the phone. You can try to fix or replace it with a new phone. But one more thing you can try to do before spending any more money is try to find a friend who has a charger for your phone (or similar one) and see if it takes a charge that way.
Feb 05, 2010 | Kyocera X-tc Cell Phone
BLENDTEC BLENDER WONT WORK WATCH DOG TIME OUT?
That is a motor issue, you need to contact Blendtec customer service. They will let you know if it is still under warranty. 1-800253-6383.
Oct 31, 2009 | Blendtec HP-611-FLP / HP-621-FLP Work Top...
Pump continues to make noise as if its cavitating when there is no water to pump.
If there is no water to pump then it is cavitating. It should turn off when the sump is emptied down and the float drops onto the switch arm
Oct 21, 2009 | RTO Basement Watchdog Sump Pump
Dell inspiron E1505 won't charge or power on period!!!
Sounds like you might have a bad dc power jack. ifyou wiggle the jack around where it plugs in on the computer, does the powr light come on?
Mar 30, 2009 | Dell Inspiron E1505 Notebook
Plumbing Logo
173 people viewed this question
Top RTO Plumbing Experts
Donni Steen
Tom Chichester
Are you a RTO Plumbing Expert? Answer questions, earn points and help others
