Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Not working only cold water there is power to it did the manuel reset still not working.
  • 518 Answers
Most likely one or both of heating elements are bad & need to be replaced.
Posted on Apr 04, 2011
Rinnai tankless water heater, modelRL94e
there must have been a power interruption during fill or while there was a flow (Water will not flow when power returns)
1. Turn of all hot water fixtures. Next press the ON/OFF button on the temperature controller twice. Will reset the fault.
Hope this does it. Let me know please.
Happy New Year!
Jan 01, 2018 | Rinnai Water Heaters
The power button wont come on to heat
Troubleshooting a Tank-Type Water Heater That Won't Start ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
Whether your water heater runs on gas or electricity, it needs a controller to cycle theheat on and off, or the water in the tank would either be stone cold or ... If the buttongoes in and stays in, the thermostat should start working again. ... Screw in a new element, reconnect the wires, refill the tank and turn the power back on.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
AFTER you establish that there is power being supplied to thewater heater .... When the water is cold in the tank the top element will come on first, heating the ... is overly hot and then notice no hot water check the reset button.
Tanklets: Electric water heater problems
Jan 25, 2016 | Water Heaters
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
They worked on our city water and now i'm getting no hot water... before that it worked but i don't think to capacity.. it wouldn't fill the tub before getting cold.... it is a rheem 50...
As long as the water heater is not leaking or not big enough that would be the only reason to replace heater. If you are running out of hot water or it's cold, check the power source first to make sure you have power to heater. Then check the reset button on the top thermostat and make sure it's not tripped if it is it wil not heat. If so press red button aloow it a little time check for hot water.
Next step woul dbe to turn power off and drain water to replace both elements out. Once changed out turn water back on and open a faucet to remove air out of the wtare lines. Once you get water flowing out of water lines now you are ready to turn power back on. allow about 30 to 40 monutes and you should have hot water.
Jul 09, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
Hot water wont get hot
1-First check for power to water heater and remove acces panels on heater to check power at thermostats. Thermostats have a reset button on them that trip and can be pressed to reset.
2- If none of the above have changed any thing and you have power you may have elements gone bad.
If an element is gone at top you will get scalding hot water then go to cold.
If an element on the bottom is gone you will get luke warm water then will get cold.
May 17, 2010 | Water Heaters
Shower will not heat up. Creda Aqua 9.5e - was working fine but now no red neon indicator and cold water only. I have checked power going into unit and is ok.
May have a tripped thermal overload or blown fuse. Some overloads reset automatically but some will have a red button to reset it with. Some have to be replaced.
May 02, 2010 | Water Heaters
Heater will not stay working
Either the switch you are toggle or the hi tempture reset is going out on it.
Mar 16, 2009 | Water Heaters
Water heats for about 3 seconds and goes cold
Take the cover off and look for reset that has trip.If you can't find no reset turn the power off and wait for five minutes,turn on and turn water on also to see if you get hot water.
Mar 14, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
