Question about Proform 595LE Treadmill Walking Belt
I have a Proform 595LE, The problem had just started.. While running lets say at 5.5 with no incline it seems to slow right down for a second and then pick right back up again. It started doing this on;y once in a while but today it did it several times during my run to the point where I had to stop. I took the cover of to have a look at the belt and the tension feels good..
4 Suggested Answers
SOURCE: proform 360p stuck on incline
I had the exact same problem.
This usually happens if you switch it off at the mains while the incline is adjusting or is somewhere other than lowest. You should always make sure before finishing off, to lower everything.
Now for the solution: If you open up the case it has 5 or 6 black philips (cross head) screws (use your user manual if you don't have your original go to proform and find the support link and download the .PDF if your model is not available get the one before or after in the same model product line (model number is below the power input)).
Make sure you remove the power before opening the cover, obviously.
Anyway, once opened, you should find a sheet of paper wrapped around in some plastic wallet. On that paper it should explain everything. Try not to mess with too much things in the settings, otherwise you might mess it up badly.
Mine is something like: Hold the speed up (+) button and then while holding the button insert the key - that will get you to the service menu (obviously the power has to be connected).
Once in the menu pressing the incline up does a self-calibration (maximum up and maximum down) after that it should be perfect.
Remove the key any time to come out of that mode and resume normal operation.
I may not find this place for any more replies 'cos i only found this site by accident. While looking for info. on my burnt out motor model: PETL 3013.6 .... But i have come across someone selling a faulty one on ebay for like 5 quids... it's picking it up the trouble!
Posted on May 31, 2009
SOURCE: Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Posted on Apr 18, 2010
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
Oct 17, 2014 | Proform 415 CT - Treadmills
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
I have a Proform xp 550 the incline won't go up...it was starting to go up then made a noise and it dropped down ... how do i fix it?
RUN the software calibration for diagnose, troubleshooitng, fix it.
2) Lube the gear+shaft from elevation Motor
3) adjust the POT from elevation motor, see diagrams attached.
God bless you
Aug 02, 2012 | Proform XP 580 Trainer Treadmill
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
I have a proform 650 v threadmil, and the left side of the buttons panel (start button and incline levels) don't work. could someone help me?
1) tight all connector wires and clean
2) tight the ribbon cables from keypads.
3) Run the software calibration for diagnose, and troubleshooting, and fix it.
4) lube the shaft and gear in the elevation motor,
5) adjust the potentiometer for better running see the diagram.
God bless you
Jun 19, 2012 | Proform Exercise & Fitness
Every time I put the key in my Proform 590T, the incline rises for a second, and lowers for a second while displaying 2 hash marks. Then, the home screen comes. All speeds work fine for walking/running,...
how long have you had this treadmill? usually when the hash marks appear it means that the console control board is not recognizing the incline motor. even though it does run a little bit that is just the basic test that the treadmill starts but resets after it does not sense the incline motor. These motors rarely go bad so it is more than likely your motor controller that is causing the issue. I have seen this case many times as i am a fitness repair technician. The motor controller fixes the issue 9 times out of 10
Aug 05, 2010 | Proform 590T Treadmill
My proform 360p treadmill is stuck on full incline - can it be fixed and if so how???
try thisSometimes incline motors will get frozen in position and need broke free. Try this:
take the motor cover off and take the screw out of the bottom of the incline motor that is attached to the screw assembly. Once you remove the screw you should be able to break the incline motor free. run the incline up and down with the screw still off( laying the treadmill on its side may make this easier). Once it goes up and down (hold the screw so it goes in and out) reattach it then run the calibration described below. If it was just stuck it should work fine.
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
If these instructions do not work to fix the incline motor
check your main harness running down the right leg for breaks in the wires or a loose connection if nothings found you can switch the red and black wires on the incline motor terminal block and see if it goes down. If it does you know you are only getting voltage to one side of the motor. There is a schematic under the motor hood that tells you what the voltage should be when you press the up or down keys. Use a multi-meter to see if you are getting the correct voltage coming from the console to the motor control board and then from the board to the motor. If no voltage from console-replace console if you have voltage from console but not from board - replace board and finally if you have voltage from console and from board replace motor. You will need to test the voltage both when pressing the up key and the down key.
Jul 14, 2010 | Proform Exercise & Fitness
Proform treadmill zt 5 runs but display is dead
If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
May 21, 2010 | Proform ZT5 Treadmill
I have a model 297980 J8 proform treadmill. when I first start it up without the safety key in it, the treadmill runs at full speed for about 2 minuets. After that it slows down and stops. The speed is set...
You have to put the safety key in if you want to select speed/incline or predefined programs.
It starts and runs at full speed on that occasion because it's part of the maintenance process, that lubricates the inner rollers so that it will continue to work perfectly for as long as possible.
May 01, 2010 | Proform Exercise & Fitness
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
Proform 595LE Treadmill Walking Belt Logo
70 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
