Question about Hampton Bay Heating & Cooling
The hand held remote no longer activates the ceiling fan or the light. I know I have power to the unit and know that the battery in the remote is ok. When I press the remote for the fan or lite the red light comes on but no action at the fan/light.
    Brigadier General:
  • 4,736 Answers
If you only change the battery in the hand-held remote, there should be another one in the fan housing that also needs changing. Always change all the batteries at the same time.
Posted on Apr 04, 2011
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
The remote on my Hunter ceiling fan (Model: 27185 - 060) does not activate the ceiling fan. I can turn the light on manually, but not the ceiling fan. I cannot see the antenna on the ceiling fan.
The first thing you need to do, is change the battery(s) in the hand held remote, as well as the battery(s) in the receiver inside the fan's cowling. Weak batteries will limit a remotes operation.
And, FYI - there is no antenna on the ceiling fan.
I hope this helps you. Thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Ceiling fan is all wired up and on ceiling but light doesn't come on or fan doesn't spin. I have checked connections and tested for power. Is there a switch or anything on receiver that needs to be...
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
I have a Hampton Bay Cieling fan, model # FAN- DH L3H2003, and the remote control does not work. How can I get a replacement?
before you buy a new hand-held remote ... have you changed ALL the batteries. There's a set in the hand-held remote and batteries in the receiver, which is behind the fan's cowling. If you haven't changed them all, I'd do that before investing in a new remote control.
if you find, after changing all the batteries, you do need a new remote control, here is a link to one for all Hampton Bay Ceiling Fans.
http://www.homedepot.com/h_d1/N-5yc1v/R-100071965/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Hope this helped you. Please let me know. Thanks.
Jun 01, 2011 | Hampton Bay Heating & Cooling
How do you install the remote transmitter in a Hampton Bay Ansley ceiling fan?
jaggirl, most Hampton Bay, Remote Controlled Ceiling Fans have the receiver already installed inside the fan's cowl. The Transmitter is the Hand Held Remote. Both require batteries.
Apr 05, 2011 | Air Purifiers
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
The fan/light will not come on with the remote. Yes remote batteries are new. The light fixture have power. I think the model # is JY97381. receiver # is UC7067RC. Unsure how to fix this problem. Can u...
Hello Susan,
If the indicator light on your hand-held transmitter lights up when you press the buttons, it normally means it's working. The problem is probably with the UC7067 receiver in the fan. One sure way to destroy the UC7067 is to have the power going to it controlled by a dimmer switch on the wall. If this is the case, replace the dimmer switch with a standard on/off toggle or an in-wall transmitter. You can find both a replacement UC7067 receiver and either another hand-held transmitter RC-210 or an in wall transmitter WC-210 at this address: http://www.fanmanlighting.com/shop/pc/viewCategories.asp?idCategory=57
Hope this helps!
Dec 11, 2010 | Minka Aire Ceiling Fan
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Airtech ceiling fan with remote, unit in fan not responding
Replace the globe with a LED that will last longer
Nov 20, 2017 | Dryers
Heating & Cooling Logo
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
