Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
My 5.5hp OHV Briggs engine is leaking gas right out of the carbuerator when it is running and the engine is flooding out with no power. What's wrong?
    Novelist:
  • 111 Answers
The needle and seat need to be replaced. The part number for most single cylinder carburetors is 398188 (briggs and stratton part number). Something has gotten stuck between the needle and the seat or the seat has either swelled or gotten so hard that it will not seat correctly. When you get the carburetor off you will need to take off the carburetor bowl. A 1/2 in socket or wrench will work ok. Then the float needs to come off. There is a pin that should slide out (may have to use some needle nose pliers to do so). Then the needle is attached to the float. The seat (rubber on most applications), is in a recess where the fuel comes out. You can remove this with an air hose.
CAUTION: When you use the air hose to remove the seat, unless you have covered it with a finger, the seat will shoot out and be lost. My suggestion is to cover the seat with a rag or something so that it does not become a projectile.
Then once it is removed you can install the new seat with a small blunt punch. (No hammering is needed.) Then you can install the new needle (included in the kit) and assemble the carburetor and re install it. That should fix that problem.
Posted on Apr 05, 2011
Testimonial: "Good advice! I have a different part number for my Briggs carb. than what you had. It works great , thanks!"
Hard stating flooding
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    https://www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    It won't start. ... Rider mower carburetor flooding - help ! .... ( HOW TO ADJUST VALVES) FIX HARD TO START Lawn Tractorwith OHV Briggs ...
    How to stop a Briggs crankcase from flooding with gas Order ...
    ? 11:34
    https://www.youtube.com/watch?v=VhEiLMtPR5M
    Aug 5, 2013 - Uploaded by doublewide6
    If your tractor keeps leaking gas into the crankcase see how you can fix the problem by ... The hard starting is caused by fuel filling the cylinder.
    Basic Troubleshooting - Lawn & Garden Tractors - Cub Cadet
    cubcadet.custhelp.com/.../basic-troubleshooting---lawn-%26-garden-tract...
    Sep 13, 2002 - Engine fails to start, Engine flooded, Crank engine with throttle in FAST... Engine runs erratic or stalls, Tractor running with CHOKE activated ...
Jan 25, 2016 | Garden
17.5 ohv briggs & stratton wikki carb floods through breather hose
My Craftsman engine leaked gas out the breather when the float in the carb was stuck so it would not close properly. The pin that held it in place came out on one side so the float would not work properly.
Aug 27, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wizard rototiller model 5hp. Briggs. Not getting fuel somehow. Fixed carberator. Spark plugs cleaned everything out... what could be the issue
is it a bowl style carb and you cleaned it is it a diaphram style and you replaced the diaphram ?the older 5hp briggs engines would run fine if you started it with carb cleaner some leaked head gaskets and could create enough vac to draw in the fuel
Mar 28, 2012 | Briggs & Stratton Garden
Engine pops, wants to start,fresh gas,every things been gone through
Needle valve on the carb isn't set right. Try adjusting it and see what happens. Also, make sure it isn't flooded. Sounds like it is
Aug 04, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Carburetor flooding
Not familiar with this model, but this is exactly how the smaller ones behave when the carburetor diaphragm is shot. Larger engines usually have a float system with needle and seat in which case the problem is either a leaking needle/seat assembly or saturated float.
Apr 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine pumps raw gas out of the carb under power
NEED TO KNOW WHAT KIND OF ENGINE. DOES IT HAVE A PUMP? IS IT GRAVITY FEED? IS THE CARB AND GAS TANK ONE PIECE? IT SOUNDS LIKE FLOAT IS STUCK OR FLOAT BOWL GASKET BAD. COULD BE ALOT OF THINGS. NEED ENGINE MODEL OR NAME ON COVER.
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
916 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
