I have a Philips 32PW9617/79 TV without a manual. How do you tune xtra channels in. Thanks
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
pishta68
  • 593 Answers
SOURCE: toshiba 2141tb tuning
there is a menu that has autoprogram in it, use that and itll scan all channels and memorize the viewable ones. Sometimes it is a stand alone button behind a door or it is in the setup menu. Make sure your antenna is plugged in. If you have cable, the only channel that may be stored is 3.
Posted on Mar 03, 2008
Inky
  • 691 Answers
SOURCE: tuning digitor tv
And this relates to camera lenses in which way???
Posted on Jul 08, 2008
SOURCE: Tuning a Channel
To Tune in Philips Machline TVs
Without using remote. Open panel on front of tv
1-- Press the menu key. --screen will now display 5 menu options--
2--press the down arrow key untill Install is highlighted
3--press the vol + key -- now install options appear (language--autotune---mantune--channel no--store)
4--press the down key to select the function required (Autotune is best) Manual is ok if the tv station's freq are known and they can be then given a ch no
5--press the + key to start the function selected ---tv will auto tune in tv stations when completed
6--press down arrow and highlite store then press ok
7--Press menu to clear menu off screen
Posted on Oct 29, 2008
asnowman
  • 788 Answers
SOURCE: Manual for Philips 32'' crt model: PW9617/79
I was able to find a link to download your service manual.
Here it is. You will have to choose the language then it should download for you. You can save it as a PDF.
http://www.nodevice.com/user_manual/philips/tv_widescreen/32pw961712/download.html
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to provide a FixYa.
Posted on May 02, 2009
I'm trying to tune my Philips 26PFL5522D/05 tv digital channels without a remote. If i press the menu button I do not get 'Install' as an option in the drop down menu. Whats wrong?
I don't believe there are analog channels being broadcast anymore, or I know around here we don't have any, the set should pull up anything that is available without doing anything special to it. Below is a link that will explain it.
Are Analog Cable Channels Still Available Enlighten Me
Feb 11, 2018 | Philips Televison & Video
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Sep 15, 2012 | Haier HL24XLE2 LCD TV
How to tune the channels
You can tune the channel by Auto programming button in the setting area and then press Auto Scans all available channel option to tune the channel automatically, try it and still facing the problem read the manual carefully for better understanding or you can also call the online customer care available in the manual.
Kindly rate my help++ Thank you
May 09, 2010 | Philips Magnavox MT1905B 19" TV
Tune channels on phillips vr656 video recorder
User Manual: http://www.p4c.philips.com/files/v/vr656/vr656_dfu_eng.pdf
Hope this helps.
May 11, 2009 | Philips Televison & Video
How to re tune a 20 pt 4673/75R Tv without original remote. Thanks John
That has a PLL tuner that retunes everytime you change channels so there is no fine tuning.
If it is out of tune, then the tv needs repair. If you need to switch from Air to Cable or Cable to Air and then Autoprogram, that would be in the menu.
The model number does not appear in my Philips cross reference. Generally, the Menu is a seperate button or pressing the Volume Up and Down together until the Menu displays.
Aug 18, 2008 | Philips Televison & Video
I have a philips powervision TV - Have lost the Manual aqnd I want to tune it into new channels. Cheers! Mike
I found a NTSC 3.58/4.43 in the street my friends and I don't know how to connect it to the antenna without a remote control is there anyway you can without a remote
Jul 20, 2008 | Televison & Video
I have a philips tv that i bought without a remote, and then bought a philips universal remote but am stuck on how to tune the channel with the remote. Very frustrating, cannot locate sticker stating brand...
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Apr 08, 2008 | Televison & Video
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
32pw9523/75m
you can put remote in auto tunning or automatic search mode,it will tune automatically. for user manual see web site www.eserviceinfo.com or philips website
Sep 20, 2007 | Philips 26PW6341 26" TV
Televison & Video Logo
Top Televison & Video Experts
