Question about Western Digital Computers & Internet
I have a WD Elements 2Tgb external hard drive, of which I have transferred a lot of videos. This works fine on the computer, but my WD TV Live HD Media Player will not recognise the ext hard drive. It works perfectly well on other external hard drive, but not the one mentioned above. Can you give me any help on this
  • kwhalliday Apr 04, 2011
    Hi, Many thanks for your quick response. Negative, there is no error message at all. The USB indicator does not light up on the WD TV Live HD Med Player. It does not recognise it at all
    Yes, thank you. Will not know for certain as it will take some time transferring the data. If any further probs, will get back to you.
  • 2,632 Answers
Welcome to Fixya. May i know if there is an error message when you connect the WD Elements on the WD TV Libe so that we will be able to fix the issue.
Thanks
Posted on Apr 04, 2011
  • Rofel Lantican
    Rofel Lantican Apr 04, 2011
    Do you have an Error like Media Library Process Failed or The Attached USB device is not Available on the home screen.
    Media Library Process Failed:
    - Make sure that the USB has no Read-Only Protection.
    - The USB is not using the HSF+ Journaling File System
    - There are enought storage space on the USB Drive.
    The Attached USB device is not Available on the Home screen:
    - The Media Player only supports mass USB storage mode. Make sure that the USB device is configured as a Mass Stirage Device.
    - Make sure that the USB device file system is supported (NTFS, Fat/Fat32, or HSF+)
    Thanks
  • Rofel Lantican
    There is a known issue that has been found with some of the 2TB Elements drives where they were formatted incorrectly in the factory, resulting in a partition that was slightly (a few kilobytes) larger than the actual size of the drive. Windows is able to handle this error, but the drivers used in the WDTV Live won't mount a drive with this error. Reformatting the drive in Windows fixes it.
    Reformatting the the drive using Windows File format (NTFS/FAT32) will fix the issue. Make sure that you back up the contents of your WD hard drive because you will lose the info when you reformat the drive.
    If you have questions please let me know. Thanks for using Fixya
Hi i`ve just bought the wd elements 320gb yesterday. the problem is that i put the usb in and the light on the product is on but thats all. its not installing and i cant find it on my computer.
The obvious question first is the drive connected with the provided AC adapter?
Are you connecting it directly to a USB port or powered USB Hub? This is not important in external hard drives but it does on portable HD. But just in case keep this in mind.
Other thing is that you have to install the WD Smartware software.
If nothing works, try it on another computer.
If it works, must be a USB port problem.
God Bless You!
Feb 05, 2011 | Western Digital Elements powered by WD 320...
How do I transfer photos to the external hard drive
once the external hard drive is plugged in to the computer check under my computer is detected if it does
open the folder where or you can right click the folder or file you want to transfer then select the name of your external hard drive.
you can also use the software that came with your external hard drive but its much easier to drag and drop the files.
hope this help
Sep 07, 2010 | Western Digital Elements powered by WD 320...
My wd elements external hd is not recognized under windows 7. The pc diagnostics say that the device is working properly and the correct drivers are installed?
Go to Administrative Tools in Control Panel. Computer Management then Storage, Disk Management. You'll probably have to recognise it and assign a drive number.
Jun 18, 2010 | Western Digital Elements powered by WD 320...
WD hard drive not opening
Something might have happened to the driver. You might need to reinstall it.
May 12, 2010 | Western Digital Elements powered by WD 320...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
WD Elements 500 GB
Hi bobo08,
I'd first check to see if the drive is working correctly with some utilities that WD provides, then once you determine if the drive works, you can either return it the retailer or it's working correctly by using these utilities. Here's the link to that drive. HERE
Good Luck
Mark
Jan 01, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Computers & Internet Logo
325 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
