Question about LG 42LG30 42 in. LCD HDTV
Tv cuts on the cuts off then cuts itself back on and back off and continues this process until i unplug the tv all together. it also toggles through the input options as well if it stays on long enough
    Problem Solver:
  • 15 Answers
Immediately open your back cover and check the capacitors. The capacitors may be damadge or some connectors may be lose.
Posted on Apr 04, 2011
My FINLUX tv flashes on standby 5 times continuously until it turns itself off...no picture or sound?
if tv is still working ok, do a reset! unplug power from wall and wait 20 minutes! Plug back in and hope all is well, good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/michael_8fc219ce5f384208
Jun 12, 2017 | Finlux Televison & Video
Model KDL-50EX645. Why does audio fail and it shuts down continually?
Sony Bravia tv turns off and on repeatedly by itself - YouTube
? 1:32
www.youtube.com/watch?v=AuWhoi5--2o
Dec 5, 2014 - Uploaded by troubleshooterrors
Sony Bravia TV turns off and back on repeatedly by itself. Green light glows on Set top box continuously, and .
Oct 03, 2015 | Sony Televison & Video
Ipod is disabled
Attach a USB connector to the iPod and plug it into a USB connection on a computer for power, or into a stand alone USB charger plugged into a power strip for electrical power.
Pick up the iPod. Move the "Hold" switch at the top of the iPod to the "Locked" position so that an orange color appears by the switch. Return the switch to the "Unlocked" position.
Repeat this process.
Press and hold the "Home" button and the button at the top right corner together if using a fifth generation iPod, iPod Nano, iPod Mini or iPod with a click wheel.
Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod.
Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo.
Release the buttons.
Wait as the iPod resets itself and turns itself back on.
or
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
hope this helps
Sep 15, 2012 | Computers & Internet
The drive belt light is flashing on the dash and the engine will not come up to speed on my 2005 750 brute force kawasaki how can i reset the computer
This belt light is a feature put on by kawasaki for safety. It'll continue to come on after it get so many kilometers on it. The light has to be reset in order to get it off. Now if your mechanically inclined i'll explain to you how to get that light to go off.
First thing you have to do is reach down under the right side of the bike and in under the side cover you'll find two black plugin and two grey pluggins. Unplug those two and then plug a black and grey together and then the other black and grey together. Then down on the belt box you'll find a square black metal box with two wires coming from it. Unplug that ****** also. Once you have this all done now turn the ignition key to the on position and wait for about 7 to 10 seconds and the computer will reset itself. After you do that, turn the ignition key off and then unplug the two black/grey connectors and plug them back together, black to black, grey to grey. Then plug the connector from the black metal box on the belt cover back in. After you have this done. Turn the key on and let it go thru it's cycle. When you are done the belt light should be off.
Now if after you have done all this, and the belt light remains on and you still have no power, then you have a switch problem in the belt box. You can either remove the belt box and check the switch inside of it to see if the switch has been tripped to off. If it has, then in all probablity you need to install a new belt and reset the switch. Personally, i'd cut the two wires coming out of that metal box i previously told you about and join then together on the bikes wiring harness side. Leave the two wires from the black metal box like they are. You don't have any warranty on that part of the bike anyhow, so why bother have that switch continue to cause you problems. In order to get the belt light to off after you cut those two wires is you'll have to go thru the process i explained to you before. Only this time at the end instead of plugging the switch wires back together, just twist the two wires on the harness side together,in theory all you are doing is plugging that plug together, only your disconnecting that switch and never again should it bother you. However, after a few 100 kilometers you may have to do all i explained to you over again, only the next time you'll have to untwist the two wires along with the two black and grey wires and then go thru the process again. After the process is done, replug black to black, grey to grey, and then twist the two wires back together, turn the key on again and let it reset itself. Again your belt light should be gone out.
Good luck
Wayne
Oct 30, 2009 | kawasaki Full Suspension Mountain Bike Men
My tv keep cutting itself off. I will have to
It could be going into power saving mode. Check your settings.
Hope this helps.
Iain
Oct 14, 2009 | Computers & Internet
Sharp aquos lines threw the picture
I've seen this problem before and if caught early (usually only a few pixels), its fixable. But if it has already started forming a "line" it might be too late and you might have a defective LCD panel. Most of the time, doing the factory initialization helps with this problem.
(WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go
  5. then at the same time press “Vol –“ and “Ch. Down”, you should see the service menu appear (if it does not appear, try pressing the two buttons again, it needs to be exactly at the same time)
  6. Then use the “Ch. Down” button to navigate down the service menu until you see “Industry Init” (NOT Industry Init +cause)
  7. Then press “Vol +” to toggle it to “ON”
  8. Then “/////////////////” should appear.
  9. when the screen turns GREEN, unplug the TV. Wait about 30 seconds, then plug the TV back in.
  10. Then continue on with the initial setup again.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos HDTV LC52D62U Caption Not Readable
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
This puts the TV back into the “fresh out of the box” settings. See if this helps with your CC problem.
Mar 15, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My tv
My tv will not turn on. We had been away for a week and no power interuption at home. We have unpluged the tv for short and long periods of time . We we attempt to turn the power on it cuts off by itself.
Mar 01, 2008 | Televison & Video
Oven won't light
you should have an igniter set up in the oven follow the the front of the burner to the end (back) you should see the igniter follow the wires from the igniter to the elec- safety valve unplug those two wires and tape them together make sure stove is unplugged before you start his process. now plug in oven does igniter light if yes safety valve is bad if no unplug oven from outlet unwrap tapped wires and reinstall them where they came from it would help if you had a ohm meter cut th wires coming out of the igniter not too short in case you have to reconnect them but you will need ceramic wire nuts the do not melt after you cut the wires from the igniter check for continuity @ the igniter no continuity means bad igniter ,i doubt the thermostat is bad but we can troubleshoot it tommorrow if these steps dont work
Jan 03, 2008 | Jenn-Air JJW8230D Electric Double Oven
RCA 27V412T TV Problem
Just to see if the set reacts and it does something different tap the sides of it,dont over do it ,I should not take much to see a reaccion if it has a loose conection,If it reacts check for loose conections in the power supply,horizontal driver transformer and any overheated areas specially after the output transformer.If you are familiar with tv service this should help but if you are not be safe and call for assistance from a servicer.
Oct 03, 2006 | RCA 27V520T 27" TV
LG 42LG30 42 in. LCD HDTV Logo
95 people viewed this question
