Question about Vacuums
I am trying to change an old fashioned fuse, (house lights), luckily had a spare one. Have put the 15amp fuse wire through the whole thing, and trying to describe if I've got it right is alitle awkward, this is what i've done, cut a piece of 15amp wire a little longer than the old one, then loking at it, taken it straight through and round to left as I'm looking at it, and put the screw in, and obviously done the same for other side. My problem is that I don't remember taking the screws out of where I'm now putting them. Sorry, its a bit long winded, just don't know how else to describe what I've done. Please say that you can understand what I've said, thank you Janet
  • 456 Answers
Hi.
your descriptions are understandable and sound about right.
as long as the wire is securely fixed to both pins, you should be ok.
if there are any problems, especially if the fuse blows again fairly soon, then i strongly recommend calling a qualified electrician to check the system.
Posted on Apr 04, 2011
Remove housing the change belt on air speed
There are screws that hold the housing for the belts on. Take all these screws out and the housing should come off. Remove the old belt You have to take your vac model number and make and ask either at a vac store or sometimes a hardware store also carries them
To replace you have to take the brush off and you should clean and lightly oil the ends and replace with the belt on then put housing back in place. Replacing all the screws.Don't try repairing with it plugged in.
Sep 09, 2014 | Eureka Vacuums
My Kirby G4 just makes an odd humming sound, but does not run , when started
take it back to service agent as maybe they forgot to reassemble and make them fix it as you've paid for a service.If you try to reconnect could fry whole thing or shock yourself.
Jun 14, 2014 | Kirby G4 Bagged Upright Vacuum
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Jun 06, 2014 | Broan-NuTone Vacuums
Henry geeps blowing fuse.why?
I would replace the whole unit itself. It's obviously shorting. What kind of vacuum is it and how old?
May 08, 2012 | Vacuums
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but...
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Sep 12, 2010 | Vacuums
My vacuum died. It won't turn on. It is not the outlet. Is it a blown fuse? How do I replace the fuse? Where does it go? This vacuum is a little over 2 years old. My older Hoover WindTunnel STILL works and...
It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
Jul 09, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Miele S514 will not come on
Greetings,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum cleaner. 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine.
Ok, so you need to replace the cord reel on a Miele S514 Solaris, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
GoVacuum.com
May 26, 2009 | Miele S514 Solaris Bagged Canister Vacuum
My Bissel stopped working and have no clue why?
Try Bissel .com, maybe you can download a manual from there. But if it just quit, the cord maybe bad. Alot of times if you unplug the cord by pulling on the cord rater then the plug, you cause the wire to eventaully break. That would be the first thing I would check. ( I am assuming that your vac just went completely dead.)
Dec 02, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
