Question about Ovens
Whirlpool gold accubake
Our oven is giving us an error message
P1- F3
what is the problem, pleas
  • Anonymous Aug 09, 2008
    whirlpool gold, accubake, stove top works, clock works, the bake button, confect button and broil buttion does nothing, I have error message F2 D0. can you help?
I have the same problem, Whirlpool is not a good, quality appliance that you could get.
For the error code, refer to link below - not all are accounted for.
http://www.repairclinic.com/0078.asp#Whirlpool1
For a end users horrible experience with this appliance manufacturer...it's worth reading.
http://www.consumeraffairs.com/homeowners/whirlpool_ranges.html
Posted on Sep 30, 2008
Whirlpool gold oven message E1-F3-
whirlpool oven starts preheating then turns off and sends a message F-3
Nov 13, 2013 | Whirlpool Ovens
How do i set clock and keep it displayed on a whirlpool gold accubake oven
http://whirlpool.custhelp.com/app/chat/chat_launch will give you a chat line where the Whirlpool expert will chat with you and help you get your problem solved
Nov 07, 2011 | Whirlpool GBD307PDS Electric Double Oven
E0 F3 Is the error code we're getting with our Whirpool Oven Accubake Gold? The oven is stopping mid bake and giving us this error code.
You should check the sensor for 1100 ohms at around 75F If shorted to frame or open then that is your problem.
Dec 17, 2010 | Whirlpool Ovens
An error message of F3 on my oven it is a whirlpool, AK2451/X1/01
Error code F3 usually means faulty oven temperature sensor and the remedy is to have the temperature sensor replaced.
Dec 15, 2010 | Whirlpool Ovens
Just bought a used whirpool accubake sc 465, keep getting E0-f3 error code, any ideas for a good fix?
Hello- The F3 error code indicates an open circuit in the temperature sensor. Pull back cover to access sensor wires.  At room temp the resistance should be 1000-1100ohms. If open, replace sensor. This should solve the problem. Let me know if this info helps- have more if needed. Thanks- Ed
Mar 13, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
Whirlpool accubake self clean oven. Error code(s) E2 - F3?
You can get all the codes here.
F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
http://www.repairclinic.com/0078.asp#Westinghouse
Good Luck and Please Rate FixYa!
Jan 07, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Gold Accubake oven
depress the broil button for 5 seconds it will revert back to Farenheit
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Ovens Logo
785 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
