Question about Vision Televison & Video
For three days i have bee unable toaccess programmes due to "freeview signal poor quality or too low level."
    President:
  • 2,187 Answers
This issue may be traced to your Freeview box. See if you can check for coverage.
Coverage:
www.freeview.co.uk/availability
www.wolfbane.com/cgi-bin/tvd.exe
www.digitaluk.co.uk/postcodechecker.
If you are within the coverage check for the actual connection itself. Check for the cables see if all are connected and secured. Any kinks or bends may damage the conductor inside it. If you are using splitters, try direct connection first if it would work. If it does not the problem may be from the work done on the splitters. It may be bad connectors or it was simply not done properly. At time you may need a booster in case there is loss in signal even all is good.
Inspect the areal. It may have gone out of its normal position or may have been damaged. You may just need to reposition it in case there are no damages. If you notice any changes or additional equipment around it may cause interference. High Power wires, devices that emit radio signals or wireless signal may cause interference. See if removing them will help.
Other than that it may be an issue with the box itself.
Posted on Apr 04, 2011
What's The Difficulties Of Stamping Parts Faced in China?
Although having being widely applied, stamping parts manufacturer in China are still facing with three difficulties.
1. Backward raw materials and related technologies
Steel made in China which is used for fasteners, chains, springs, bearings and moulds has poor quality and few descriptions, having direct influences on quality of stamping parts. In general, mechanical components are manufactured in batch and quantity, and products also require for various varieties and high machining precision. Those have high requirements and large investments for manufacturing technologies and equipments. Overseas, special equipments, production lines or flexible production lines which having high efficiency and precision are adopted to realize highly efficient automatic production. However, in China, due to being limited by capitals basic parts manufacturers have few investments on production lines.
Besides, enterprises have poor self-improving ability, lacking of advanced equipments and matching equipments, which has high impacts on quality and grade.
2. Insufficient funding, weak research and development
In the late of 1970's and early of 1980s's, hardware industry had ever imported advanced technologies from abroad. However, the industry is lack of software and hardware devotion to absorb technologies. According to experiences from abroad, required capital ratio between technologies input and absorption is 1:7. But, China acknowledged it late and the absorption was slow. The essence of market competition is the contest of technical strength. At present, large numbers of colleges and universities engage in scientific research. Lots of theoretical researches, scientific payoffs and patent papers have high level. But, they are less combined with actual production, especially low velocity of transforming into stamping parts.
3. Low professionalization and poor economic benefit
Compared with main machines, sparing parts manufacturers require less investments for establishing initial capitals and technologies. During several great economic developing periods, a batch of private manufacturers sprang up. However, because of various market demand points, low batches, those manufacturers cannot form economic scale. Most of manufacturers have low professionalization and level of equipments, instable quality and poor economic benefit. Metal Parts Custom Manufacturing Assembly
Jan 19, 2017 | Cars & Trucks
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
My lg 42pg3000 has hd but none of it shows up as good as hd, only from sky programmes not on freeview
the set can only deal with the quality of the signal it gets---freeview is freeview.
Jul 17, 2012 | Televison & Video
I Have a 15inch acoustic solution telly with built in freeview model number astv15id , however it has lost most of the freeview channels how do i retrieve them back.
Go into main menu set up and navigate to option to rescan. (might be called install or re-install stations)
Note - if it has lost channels it may be due to poor signal quality - check the quality of your aerial connections. You may also have lost channels if your area has recently been subject to 'digital switch-over' . Although they are already on digital tv all Freeview boxes will need re-tuning after switch over because this entails a change of some channel frequencies post analogue.
Feb 26, 2011 | Music
You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal
Due to your low internet speed, the message shows. Or try restarting the modem.
Thanks for joining us.
Have a good day.
Jan 07, 2011 | Yahoo Messenger
Printing quality is poor. Color has scratch and dirty. Color distotion
Printing Quality of Printer is Poor due to some reason...
* the toner has low level of ink material...
* some problem in the toner pad,,,
* scratch are due to above two reasons and the problem in Roller of the printer....
Aug 16, 2010 | Lexmark C522n Laser Printer
Why doesnt the lowry freeview box have itv channel 4 or 5 whats the point of selling it?
Are you in a poor signal aera? The Lowry box is shockingly bad at picking up low signals. <br /> <br /> I had lots of problems with it, including a missing/intermittant itv channel.<br /> <br /> I swapped mine for a phillips
Feb 13, 2010 | Televison & Video
Jul 04, 2009 | Yahoo Messenger
After an electrical storm last night we have lost ITV, Ch 4 etc on Digital, BBC and Sky on freeview are fine. All analogus signals are of very poor quality. Any ideas please?
Electrical Storm normally damage Tuner in TV.
Symptoms in tv like poor analog tv signal reception shows replace TV Tuner.
Regards,
Sep 03, 2008 | Televison & Video
Televison & Video Logo
97 people viewed this question
Top Vision Televison & Video Experts
D. E. Hev
shaun taylor
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
