Question about Frigidaire Dishwashers
Frigidaire Dishwasher Model #FDB1500LFS2 After finishing all cycles, no problems at all. But if it was not in use for couple days some dirty water back up at the bottom. Then just let the machine run and wash another full cycle, everything is fine, but couple days of no using , dirty water back up again
Falling Down
  • 67 Answers
SOURCE: Dirty Dishes after dishwasher has finished
You may be getting sand in from the supply lines. Fill a clear glass container from the sink a few times and look at the bottom for sand particles. You may be getting sand from a pool filter? Remove the filter from the faucet head (it should unscrew) and look for sand particles in it. You may not be getting them in the kitchen sink if the dishwater inlets are below the sink as the particles may be sinking to the bottom of the pipes. You may need to put a filter in the dishwasher inlet. Try filling the dishwasher by hand with bottled water once and then see if the sand is still there. If so, it probably comes in through the water supply.
Posted on Nov 30, 2007
  • 1314 Answers
SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Posted on Jan 17, 2008
aborcass
  • 2651 Answers
SOURCE: Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Posted on Feb 26, 2008
  • 131 Answers
SOURCE: Frigidaire dishwasher dirty & sticks in cycle
First, check the holes on the upper spray arm. They should be clear of food and debris.
Next, There's a check valve (ball) built into the motor unit. Either it's stuck, or the motor isn't pausing at the appropriate time to switch from bottom spray to top spray. You can test the check valve by opening the door momentarily while it's running. The spray noise inside should sound distinctly different. Pausing longer will switch back to the lower spray arm.
If the check valve works, you'll need a new timer.
Posted on Mar 10, 2008
  • 6 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
Draing Problems:
To fix your draining problem you need to check the air gap(if you have one) , check if there is voltage going to your drain pump during the draining cycle. If there is voltage coming to your water pump and the dishwasher is still not draining then the problem could be a clogged drain hose, a clogged air gap or a bad drain pump. if there is no voltage detedcted on the drain pump during the drain cycle, then it could be a water level-switch/solonioed , wiring, or a control board problem.
Good luck.
Mr Engineer
Posted on Aug 11, 2008
My Frigidaire Stainless steel FFHB2740PS D.D. has an error code that reads 5H. What is wrong?
I appreciate your inquiry, friend!
Based off the information you have provided your Frigidaire dishwasher is displaying an error code of "5H". That appears to be the time remaining on your wash cycle. Typically an error code would be displayed with a number and an "E". What is the current problem with your dishwasher? Are you getting long wash times? There is a sensor inside of your dishwasher that reads how dirty the water is, if your dishwasher continues to circulate dirty water it will tell that sensor to continue washing. You may want to check your filter, which is located at the bottom of the tub, for any debris. Additionally, if your drain hose is restricted it may be providing dirty water back into your tub. I hope this information is helpful to some degree. -Matt
Feb 24, 2015 | Frigidaire Dishwashers
Dirty water backs up into unit
The drain valve needs to be checked , also try cleaning the drain hose , it could be clogged , leading to improper drainage .
Lemme know if this helps
Mandeep
Apr 20, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Should any water remain under the glass trap after cycle has finished on a frigidaire dishwasher?
Good Afternoon Friend,
I understand that you want to know if any water should remain under the glass trap, on your Frigidaire dishwasher, after the cycle has finished. Per the owner's manual, "it is normal to see a small amount of water under the filter at the end of a cycle." Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Dishwashers
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
My frigidaire dishwasher FDB1502RGC4 will not run a cycle. it will fill and drain the water but will not run a wash cycle. all the lights on the control panel lightup when they should. so i dont think it...
having the same problem with mine, just replaced the discharge pump last week because it went out, worked a couple days now this. still have not figured out the problem
Dec 01, 2010 | Frigidaire FDB1502RGC Built-in Dishwasher
Cycle does not finish leaving dirty water bottom of tub without draining out
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 12, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
At the end of the cycle, there is several imches of dirty water on the bottom of the tank. CHecked hose and thingst looked ok
heatman101
Aug 28, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher won't wash
pump is likely gone ......without pressure from the pump .the arms will not turn and no water will shoot from the arm jets .....it's kinda like a whirlpool tub that way .....no pump no bubbles ..good luck
Jul 25, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire Model FDB2810ldc0 s/n:TH43526319
Dishwasher is leaking water from underneath during the rinse cycle and a small drip during the wash cycle
Sep 22, 2008 | Dishwashers
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
