Question about Watches
I have to set it everytime i put it on. it good when i wear it. is it the battery?
    President:
  • 2,501 Answers
What make and model watch do you have?
(is your watch automatic? if it is, then these only run for 2-3 days at most before stopping and need to be used daily to maintain their operation.)
Posted on Apr 05, 2011
Raymond Weil Jasmine losing date everytime I go to wear my watch which is really on special occasions i find that I have to wind the watch to get the date right would this be a simple battery issue?
the problem is some month's av 28 days and some month's av 31days, but on your watch the wheel that as the numbers on has 31 days so if there's a month with 28 days you'll need to change it manualy hope this helps you,,
Aug 01, 2013 | Raymond Weil Watches
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
Jan 23, 2012 | Michele CSX Diamond watch
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Jun 27, 2011 | Armitron Now Collection Crystal Accented...
I have a shilotte citizen eco drive mispelled sorry I have had it for about 4 years the last year I haven't use it much cause i only use it for good wear or sunday best took it out of the case yesterday...
The watch will have to be put in a strong light for some time to charge the battery.
If you go to http://www.citizenwatch.com/COA/English/home.asp and click on "recharge guide", you will get all the information you need on recharging the battery.
Apr 25, 2011 | Citizen Eco-Drive Calibre 8700 Wrist Watch
How to prevent water leaking inside,after replacing the batteries.. should i replace the gasket to? after replacing the batteries....
Normally gasket has not to be replaced after battery change.But all depends of the use.For example if you wear the watch in salt or pool water and never flash it with fresh, clean water after,it may be a cause of gasket wear.Remove the back cover.Replace all 4 batteries(be sure first that you can do this with extreme caution as all parts are tiny).Remove gasket.Check gasket condition(cracks,gasket too dry and hard).If gasket OK, apply a small amount of special silicon compound for watch gaskets,all around and to all sides of the gasket,put it back in place,carefully.Be sure that gasket is set correctly all around.Put the back cover in place and screw with much caution (not too tight-a little resistance).Your watch now normally is water resistant.But if you want to be 100% sure,take the watch to a serious repair center where it will be tested under pressure ( 3 Atm average).Then they will tell you if your watch is 100% water resistant.
Oct 11, 2010 | Casio PRG-40T-7 Pathfinder
WILL RUN A SHORT TIME THEN STOP
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Jul 01, 2010 | Rolex Day-Date President 118238 Wristwatch
Breitling Colt Kinetic Watch - not working
I read the instructions for a similar type of watch and while the battery will keep the watch "alive" for some months when not in use, eventually the battery dies.
Since it is a kinetic watch the instructions I read said that you should gently shake the watch about 500 times to recharge the battery!
If you give it a good shake and then wear it for a few days, it should recharge itself, although it may have forgotten the time and may need re-setting.
Mar 01, 2010 | Breitling Colt Oceane 504 Watch
How do I adjust my time
hi friend,
i think your rolex watch must be a automatic one. this kind of watch, you don't need to put battery, after in full power, i can last 24-48 hours. if you wear it, it will not stop, but if you don't wear it for long time, it will stop automatic. to adjust the time, you just need to wind the crown counterclockwise, and then pull out the crown, and then you will hear the sound of "click" and then find the right position, and then wind the crown to change the date. please note that the date have to change from small number to big number. after adjust it, you have to screw down the crown to a good water proof capability.
source form: Swiss ETA watch
Sep 30, 2008 | Watches
What to do with watch repair kit
Unless the watch back has notches on it, you want to look around the edge of the watch and find a little lip. When you find the lipp, use one of the knives and pry open the back. Take one of the tweezers and pull out the battery, you could also use one of those handy-dandy screwdrivers to pry out the battery. Put the new battery in laying exactly like the old one , then proceed to close the back, making sure that the little notch (on the INSIDE lip of the back case) lines up with the stem and crown (the part used for setting the watch) so not to break it. The back openers and the knives are just differant ways to opn the back of the watch. Sometimes watches have screws on the back that need to be taken off in order to open the back case. The case vise is to minumize the wear and tear on your hands. The tweezers are for taking out the battery. If you have anymore questions PLEASE feel free to contact me I will be glad to assist you further! Good Luck!!!
Aug 12, 2008 | Watches
Small 'eye' icon??
The "eye" icon appears when you have your backlight set to auto. that means when you move your wrist to look at your watch the light comes on automatically. I have found this to be a huge drain on the life of the battery. to turn it off hold down the light button (the grey button on the front with the red "g" on it) untill you hear it beep.
As for the watch dieing when the alarm goes off that is a good indication that you need a new battery.
Mar 08, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
