Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
He power on when i put the charge cable. What can i do?
    Master:
  • 395 Answers
That means your battery is no longer charge. This is very common for netbook. It may be time to buy new battery. you can find cheap one online.
Posted on Apr 05, 2011
The secondary handset doesn't charge anymore, no breakages ect just wont charge. Could it be the charger or the power cable not working ?
Try to charge it on the main. If won't charge, it's the battery.
If charges, put it on secondaty. Does it make any "click" or turns light on? If you won't get any return, might be the power cable OR the charger set, but you need an electronic tester to check the cable.
Jul 02, 2015 | Lands Phones
How do i charge my nabi2 if my charger hole is broken
If it truly is the connector in the Nabi, you're in a bit of a jam. But, the power cords I find are very finicky. I have two Nabi's and each has its "preferred" charging cable. One cable works better than the other on each tablet. Before attempting any major repair, try another USB charging cable. You can get the cable for under $4 on Ebay. Make sure you have a high powered USB source (2 Amp or 2000 milliamp) or it won't provide enough juice to charge the tablet. Beyond that, I also sometimes have to "position" the cable just right, twisting the connector and cable till I get the red charge light to stay on. Often this requires I fully power off the Nabi, not just put it into stand-by. Good luck.
Feb 26, 2015 | Nabi 2
Hello / I have a Galaxy S. I am having problems getting the phone to charge When plugged into the charger, I see the picture/LED of a dead battery and then it blacks out... or I see a picture/LED of a
I have a hard time keeping the cables working. Try changing the cable out. Also try holding the cable and putting slight pressure upwards on the bottom of the connector. The charging symbol has to be on if it is charging.
Feb 08, 2015 | Samsung Galaxy S Cell Phone
It goes dark, shuts off constantly. Battery meter isn't showing charging.
Unplug the battery and plug in the AC power plug into the laptop;
Does the laptop start up and stay on?
If yes,
Then put the battery in WHILE IT IS ON; See if it starts charging.
If it does not; You have a bad battery and need to replace it.
If it does start charging here's what happend;
Some laptop batteries if they are fully depleted on charge will not let you power up the laptop EVEN IF the power cable is plugged in. In some cases the PC won't turn on at all.
The reason for this is because the battery must have a certain % of charge in order for you to start the PC even IF the power cable is plugged in.
By removing the battery we eliminated the battery as being a cause for this issue; Once the PC is up and running in windows.. LET THE BATTERY CHARGE! You'll want at least 10% charge minimum for the PC to start up.
If however the battery replaced still doesn't hold a charge it's going to be the AC Adapter power cable that's causing the issue.
Best advice start off with the power cable replacement first; This is the cheapest to fix; Otherwise the battery can cost in excess of $50-$150 or more. But universal AC power adapters can be cheap $70 or less which varies depending on laptop.
Sep 30, 2013 | Toshiba Satellite L655-S5101 Laptop
I can not find my power cord for my m4002a mp3 player where can i get a replacement cord
To charge it from your computer?
Any usb cable that you can plug into your player should at least charge it
Take it to a computer/electronics shop and ask for a usb cable to fit it.
There are two types, charging and charging/data, with the data cable having all wires connected through so you can put music on your player from the computer.
I checked on eBay and put in "rca m4002 cable".
I found one for under $7 including postage, charging only.
Jan 28, 2011 | RCA M4002 Digital Media Player
Toshiba quosimo f45. laptop wont boot at all ,fixed once by them
hi there,
dont panic brother,
try theses things.
--> take out battery
--> connect the power cable
--> wait for a minute
--> turn it on
--> it will work
if not
--> take care power cable out
--> put the battery in
--> turn it on
--> and it will work (try to move the lid up and down)
if not
--> charge the battery dont turn it on
--> when its full take of the power cable
--> wait for 30 sec
--> turn it on
--> it will work ((try to move the lid up and down)
if not
--> keep the power cable
--> turn it on
--> it will work (try to move the lid up and down)
best of luck
Mar 23, 2009 | Toshiba Qosmio F45-AV410 Notebook
Hp ipaq seems dead
Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
G1 Phone Wont Charge
take the batteries out and put it back in again and try charging check in diff power sockets press the end of the charging cables with little amount of pressure and have a check try to connect via the usb cable to the computer and check if it charges, if works the charger is faulty if still did not work then it will be firmware problem with of phone
Nov 03, 2008 | HTC G1
Won't turn on
Best regards,
Oct 27, 2008 | HP iPAQ RX3715 Pocket PC
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
