After a thunderstorm the circulating fan runs but the igniter doesn't function. a small red light is slowly flashing on the service panel.
    Brigadier General:
  • 4,736 Answers
Mewing - It would really help to know who the Manufacturer is and the Model Number. Without that info it's difficult to help you.
Posted on Apr 04, 2011
My TV will not turn on. It has a flashing red light on the small display
Is the power button just flashing, is this what you mean by 'smal display'? Try troubleshooting with the instruction manual. Check the aerial/antenna is properly connected and functioning etc. If no joy just return it to the retailer for service of your warranty.
Jun 12, 2015 | Televison & Video
Gnev120w Made a noise, now not freezing.
the fan only controls air circulation. not the function of the motor. sounds like ur fridge is stuck in the defrost mode? check ur cold control thermostat with a multi meter for continuity. the fan does not run while in defrost mode, u can manually check ur defrost timer in the fridge by sticking a small screwdriver into the hole underneath it, and turn clockwise till u hear a click u should hear the fan and compressor come on if not turn 1 more click?
Mar 19, 2015 | Beko Refrigerators
Bryant gas furnace does the blower motor have to work for the heat exchanger to light up both are not working
It depends....on if you are talking about a small blower in the front of the furnace or the indoor fan motor. If your furnace is an 80% effficiency rating or above it will have a 'combustion air' fan....that will be a small on in front of the furnace in the vestibule under the front cover. If you have that motor and that is the one you are asking about...then YES it has to be running prior to the furnace igniting the gas.
If you are talking about the indoor fan motor for circulating air into your ducts, then NO it does not have to be running in order for the furnace to ignite. But it WILL have to run to remove the heat from the heat exchanger after it ignites or it willl overheat and shut off on high limit.
Jan 02, 2015 | Heating & Cooling
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Tv does not swich on. The red led light plinks 5 times.
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
There is a chance that the bulbs are not bad, but you will need a small fan to test this. Place a small fan blowing directly behind the set and run it for several minuts before turning the set on. This may help clear the code and allow you to watch tv if not then your lamp or driver has gone bad and needs replaced.
Jul 02, 2011 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
Service engine light and passlock light comes on , the needles on the dash all dive to zero then return to running position or the seat belt light comes on and off ,or the fuel light comes on and off. The...
Here is some info about the Passlock light. http://vatspasslockpasskeysecurityhelp.yolasite.com/ If this is happening while driving, the passlock failing could cause all the needles to jump around. It might be the connection between the key, ignition, and computer losing and then regaining connection.
May 24, 2011 | 2003 Pontiac Sunfire
I have just bought a Wharfedale ICS182 in-car radio but it doesn't seem to work. The red light that indicates power works but nothing is happening. Please help.
Take the control panel off.
Turn ignition off.
The alarm led should flash slowly.
Turn ignition on
The alam led should flash quickly.
If it stops flashing, take the radio out and get it repaired/replaced under warranty.
Dec 28, 2010 | Car Audio & Video
Service engine soon light is on
How to reset (erase the light):
Open the fuse access panel on the driver side. Youll see a small rectangular red button labeled RESET.
Turn ignition ON
Press the RESET button repeatedly until you see the SERVICE ENGIN light flashing on the dash.
Press and hold the RESET button for a few seconds until you hear 5 'dings'. It will turn off.
Turn ignition OFF.
Drive safely.
Good luck.
Please rate the solution....
Jul 03, 2009 | 2003 Oldsmobile Alero
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
