Question about Axiohm A794 Printer
Axiohm a794 with rs232/usb interface will it work just rs232 and no usb converter
I need the USB drivers for PC USB 2.0 to RS232 converter cable
hi Oscar.this is all i could find on the internet.
go to this link it might help you out but not sure.
USB drivers for PC USB 2 0 to RS232 converter cable Google Search
Nov 19, 2017 | The Computers & Internet
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
NEED WIN 7 DRIVER FOR GTCO CalComp Drawing Board III
Drivers for GTCO, GTCOCalcomp or Calcomp digitizers for Windows XP, 7 and 8 can be downloaded from this url:http://www.interworldna.com/GTCO/gtco-drivers.php
If you are trying to use your digitizer with AutoCad these drivers will not work and you will need to buy a driver from VTABLET.com (They provide a 30 day free trial/demo) only works with serial RS232 interface. If your digitizer uses USB then you will need an interface kit for your specific digitizer to convert it to RS232. Most new digitizers come with USB, some have serial but require you to buy an interface kit. Contact your Digitizer supplier.
If your digitizer is a GTCO, GTCOCalcomp, Calcomp or Summagraphics brand, try these guys: http://www.interworldna.com
They do not know about any other brands. Wacom contact Wacom, Numonics contact Numonics. If you have Mutoh or Science Accessories or any other brand you are on your own as those manufacturers have all gone out of business as far as I know.
Dec 06, 2013 | GTCO CalComp Drawing Board III 34180...
How to connect ddx3216 to pc
You need to either connect it using a MIDI interface card and cables from the PC or you can use a RS232 serial cable which may be hard to find for your PC. It appears to use the 7 wire RS232 type connector at the mixer board end. You can get USB to MIDI converter devices from several sources.
Aug 12, 2011 | Behringer XENYX 2442FX Mixer
Garmin GPS 76S USB interface data cable
The convertor has a microchip in it to do two way signals. Not a DIY project.
Others are available online for less than $5-10.00. Try Ebay.
Good Luck
Mar 05, 2010 | GPS
Magellan SL Scanner/Scale PC Connection
first go to posspecialist.com ok get a usb sr232 converter than it will work but not in vista with xp ok
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_08785c7d726a554e
May 19, 2009 | PSC Magellan SL
Problem with an usb-rs232 adapter
There is a good chance the weak spot is your serial to usb adapter. The signals are not compatible so the adapter has a chip and serial driver to convert the signals. If the adapter is not fast enough to convert the signals, you get an error. Here is some more info on adapters.
5 Steps for Selecting the Right USB to Serial adapter
Mar 04, 2017 | Televison & Video
QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Aug 28, 2007 | PSC QS6000 Plus Handheld
Computers & Internet Logo
114 people viewed this question
Top AXIOHM Computers & Internet Experts
David Payne
David Payne
Are you an AXIOHM Computer and Internet Expert? Answer questions, earn points and help others
