Question about RCA TruFlat 27F520T 27" TV
Can you hi definition with this tv?? - RCA TruFlat 27F520T 27" TV
  • RCA Master
  • 6,993 Answers
The answer is "NO".
I hope this is clear.
Good luck.
Posted on Apr 04, 2011
50 INCHAdjust picture size to fit screen
Picture size depends on how the program is broadcast to the TV. You can use shrink, letterbox on some tv's to expand a picture but the aspect ratio will be wrong. There is no adjustments if a program is broadcast in standard definition and viewed on a HI definition TV.
Apr 03, 2015 | Televison & Video
Zenith tube tv has thin white lines but no picture and I can hear audio
Hello jreese, Hi, Most definitely its a horizontal output problem, your tv has no horizontal deflection to pull the screen vertically, the power transistor that produces the high voltage is bad, this needs to be replaced. definitely you always have sound, the audio section is a separate block from the high voltage block, go look for a technician to have this checked.
Mar 03, 2011 | Zenith B36A24Z 36" TV
How to connect a sony blue ray disc Dvd player model BPD-s470 to my Sanyo Dp32647 32in TV.
Hi Definition Sources (your Blue Ray Disk Player) and Hi Definition Display device (your LCD TV) interconnect to each other using HDMI cable. You can buy them in your local Electronics store or online at desired lenght.
Feb 24, 2011 | Audio Players & Recorders
I am getting standard definition but not hd
Is your TV capable of displaying high definition? Is it an HDTV? If so, go to the Settings on your XMB (Press the Home Button) and into the Settings menu. Look for the option which says Display Settings. This will guide you through the configuration wizard and determine the best possible output for your TV. If it doesn't output at least 720p then your TV is not capable of displaying high definition.
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
I have hdmi cables connected and am trying to watch in High Def, but its only displaying in 720p what can I do to fix it
That is Hi-Definition - it's just not as hight as 1080p
Is your TV definitely capacble of 1080p?
If so, check the source output settings
Jan 23, 2011 | Sharp LC40D68UT 40 in. LCD TV
I can't seem to get this tv to get high definition using att uverse. Is this not really an hd Tv?
hi! just a tip ,i think it is a HDTV ive check on the specs for this tv, you can actually adjust the aspect ratio of it to a higher resolution. for more information you can actually call uverse and they'll guide you to set up the aspect ratio on to your tv. hope this would hel. goodluck!!!
May 21, 2010 | Astar LTV-27BG 27 in. LCD Television
I HAVE A HI DEF BOX AND IT IS CONNECTED TO MY TV VIA A HDMI CABLE BUT PICTURE IS NOT HI DEF. DO I NEED TO ACTIVATE SOMETHING ON THE TV ITSELF?
HD signals are automatically sent from the receiver to the TV and are displayed as such unless there is a setting on the HD box in the on screen display to drop the signal to standard definition.
Its also imperative that you have HD programming and that that you are tuned to an HD channel. Since the box itself is backwards compatable it can display Standard Definition signals.
What is the model # of the box. Perhaps I can guide you to the settings.
Aug 11, 2009 | Toshiba Televison & Video
Blinking
Hi, the capacity of your TV is not good for Hi-def.. the resolution of your TV should be equal or less to the capacity of your TV. See the manual for the best resolution for your TV
Jul 06, 2009 | Toshiba 46H84 46" Rear Projection...
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
High Definition
If it has the green blue and red inputs on the back then you will get hi definition picture in 480I only
Apr 06, 2008 | Televison & Video
RCA TruFlat  27F520T 27" TV Logo
13 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
