Question about Sony DVP-NS575P DVD Player
When playing a DVD, I get sound but not a picture. The message on the screen is no input, check input. I have checked the cables at the DVD and at the TV and both are connected correctly, i.e. red to red, blue to blue and greeen to green. Also I have changed DVD's and the result is the same. What should I try next?
  • Sony Master
  • 512 Answers
Have you tried using standard RCA AV cables? yellow-red-white - to TV. Or have you tried using an S-Video cable (a 5-pin mini DIN plug) between your DVD player and TV? if your TV has S-Video input, and your player has S-Video output, a cable for this should be easy to obtain and connect. Not expensive either.
Your TV should automatically detect the connection of S-Video (if it has this feature). S-Video is better quality than standard RCA yellow AV cable. (you can leave the existing component video connected)
You can also check your DVD player 'setup' maybe it is incorrect - make sure when using component video (red-green-blue) to set the player's output to progressive (for a TV that supports it) - unless it is already set to this.
If everything in the setup menu checks out OK, go with the cheap and easy S-Video cable suggestion. Radio Shack may sell these.
Posted on Apr 05, 2011
SOURCE:
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
When playing a dvd it has picture but no sound.
Check ur inputs and outputs cables connections?Yes,Change the RCA video AV component cable or the HDMI cable,which ever u connected this DVD player in.U might,just have a bad cables problems.
Dec 04, 2010 | Toshiba D-R5 DVD Recorder
I am receiving no picture when I play the dvd
check cables.check for video mode on remote
Jul 08, 2009 | Televison & Video
No sound for TV AVR 786
Check cables, see if other audio sources work through audio input ports.
Apr 24, 2008 | Denon AVR-786S Receiver
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
PC Input Cuts out after DVD starts playing
Try another DVD disk. If this does not work, then it is possible that the drivers became corrupt, or the drive, or the controller has gone defective.
You try uninstalling the drivers and the drive for the DVD drive, and then re-installing them back again.
Jerry G.
Dec 24, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
No Picture on TV
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
   Sorry to ask so many  ?????   Let me know how it goes!!  T.
Oct 17, 2007 | Televison & Video
DVD plays with sound but no picture
Have you checked the unit on another input or another set to eleminate the video input? also try the video cable. If theres sound and no video and you tryed then the video output amp in the player has a problem and the only way to fix this would be with a schematic and a scope to trace out the video signal. Good luck
May 25, 2006 | Toshiba SD-230 DVD Player
Sony DVP-NS575P DVD Player Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
