Question about Teac AG-H350 Receiver
I am trying to assign an Xbox 360 to a digital input on my Teac ag h350 but it keeps flashing at me. I have tried both digital inputs and no sound comes out. Help!!!
3 Suggested Answers
SOURCE: XBOX 360 to JVC RX 5060b
I had the same problem. You should check to make sure that the switch on the XBox cable is set to HDTV and that you change the resolution on the XBox to 720P/1080i.
Posted on Mar 07, 2009
SOURCE: Teac AG-V8520
same problem exactly
Posted on May 31, 2010
Can i plug in a turntable?
the manual should tell if able and how, press the helpful button and check the link for your manual
Teac AG H350 Manuals
Jan 20, 2016 | Teac AG-H350 Receiver
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
Can I connect an active speaker to the Teac AG d7900 output
http://produto.mercadolivre.com.br/MLB-184407791-av-digital-home-theater-receiver-teac-ag-d7900-_JM
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
Aug 17, 2011 | Teac AG-D7900 Receiver
I would like to run my TV sound out of my TEAC AG-D9100. Can I connect my TV sound output to the VCR/VIDEO4 input without a video input and then switch to VCR VIDEO4 to get the output sound? I have the...
Yes, and if you have a cable/sat/dvr box why don't you just run ITs best TV-related audio into the receiver without watering it down through your TV?
I'm not so sure that running the TV video through anything else serves any purpose. Once TV has it where else do you need it?
Apr 30, 2010 | Teac AG-D9100 Receiver
Surround Sound won't go on. Connected and setup all speakers. Did the speakers test. And playing a DVD surround sound won't go on.
You don't say what the DVD model is and how it's connected. What DOES work? Is surround not working for other sources, too? Have you connected the DVD player to other inputs to see if the problem is in it or the receiver? Is the digital input on the receiver assigned to the DVD player? You have some homework to do.
Jan 19, 2010 | Teac AG-D8900 Receiver
Can I hook a turntable to a Teac AG-D8900. Where do I input?
only if the unit has a PHONO input never plug a turntable into any other jack as teh voltage is different.
I have seen an adapter so that you can plug a turntable into an ordinary input I believe Radio Shack but that was along time ago try ebay
Jan 08, 2010 | Teac AG-D8900 Receiver
Sound Cutting Out
Somthing is tripping th amp breaker...
Try unplugging it for several minuets & see if clearing it helps..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Teac AG-780 2 Channels Receiver
Teac AG-V8520
Oct 13, 2008 | Teac AG-V8060 Receiver
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
Teac AG- D8900
Stereo Tech: Check speaker switch(A or B) also be sure you have selected FM, AM, Video, CD ect., somtimes if you do not have a stereo signal the unit will mute best to fist try tape or CD input. Hope I helped good luck.
Nov 27, 2007 | Teac AG-D8900 Receiver
Open Questions:
Teac AG-H350 Receiver Logo
26 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
