Question about Garden
First time using a chain saw. put the oil in. plugged into an extention. pressed both safety and trigger buttons together, but nothing happens. is there any other lock that i need too release to get it started
  • 2,239 Answers
Most electric machines will have a micro switch connected to the chain brake, grab the hand guard and pull it fully back the the top handle, you should hear a click as the brake lpcks, now try again.
Posted on Apr 04, 2011
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
My chainsaw wont start. electric souce is good, but nothing happens when you press the trigger.
Check the chainbrake is fully pulled back to the top handle, many electric saws have a micro switch to prevent the saw from running with the brake on.
Jul 16, 2011 | Mcculloch 16" Electric Chain Saw Mcc3516f
My chain keeps freezing up on me and its brand new. how do I fix tha t on my husqvana 16 inch
Turn the chain brake off, then remove the bar and chain. Clean the side of the engine where the bar fits to, start the engine and observe whether the small oil port on the engine oozes out oil. If nothing and the oil tank is filled, put the saw back together and take it back to the seller for warranty repair of the oil pumping system or a fresh saw in exchange. Hope this helps!
Dec 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Pull trigger and saw does nothing
Assuming you are using an outside plug with a long extention core - it may be that you tripped a GFI (Ground fault receptacle or breaker) Short of that purhaps the trigger or brushes have failed? let me know how you make out.
Nov 29, 2010 | Remington Electric Chain Saw
Chain oil tank full, feed channel behind guide plate clear, but no oil going to chain when running. This is a homelite 16.
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Nov 15, 2010 | Homelite ZR10926 16 Chain Saw
Electric chain saw has not been used in quite some time and when I plugged it in and pulled the trigger, nothing happened.
with the eaw unplugged, try pulling the chain by hand to turn the motor to a different spot on the armature.
Jan 26, 2010 | Garden
Can not unlock saw
there is a safety button[usually by thumb area when u grab handle ] on most saws that has to be pressed as well as the switch when using circular saws
Jan 18, 2010 | Saws
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
My 18 V ryobi chain saw doesn't activate
Batteries need to be stored fully charged and recharged every month or so while in storage. Batteries need to be kept cool. Try another battery to see if the battery is bad or if the saw is out of order. Contact Ryobi @ 800 -525-2579 The full extent of your message did not appear on my screen. So I am not sure this helped you.
Jan 22, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
