Question about Yaesu Radio Communications
Yeasu ft840 turns on display lights flash no audio or xmit
  • Anonymous Mar 20, 2014
    no transmit or receive flashing diplay
  • 12,061 Answers
Panoptic.com/rking/ham/FT840-Service_Manual.pdf
service and repair manual at above link.
If there is NO audio and no xmitt, then it is most likely something common to both circuits? Anyway it's not really possible to diagnose a fault, via a forum, unless clear cut, which this is not, your best course of action is to work through the troubleshooting steps and see if you can isolate your issue.
If DIY isn't able to be done, then the best bet is to contact a Yeasu local or head office, or over the 'net, and ask for a referral to an authorised serve center, here ask for a "Quote" as to costings and type of repair, this way then at least you can make an informed decision,as to what to do.
Posted on Apr 04, 2011
Denon AVR-1312 turns on displays for a second switches off and the red light starts to flash
you most likely have a shortedchannel in the amp that would need to be repaired
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
Yeasu Ft215a keypad doesn't work
Call a technician to check it for you please
Apr 18, 2014 | Sharp XE-A101 Cash Register
After Flash Update (v0227) will not xmit proerly
I would flash it back to the older version. Double check you have the correct firmware. This almost sounds like the incorrect version for your radio.
Apr 12, 2014 | Yaesu FT-450D Transceiver
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
No audio output on transmit modelyeasu ft840
Are you referring to reception through your radio speaker, or transmission to another station?
If it's reception, then what antenna are you using, indoor or outdoor?
I need answers to these questions, before I try to resolve your issue.
Please reply with as much detail as possible, don't be afraid to ask questions in full detail, the more info I receive, the sooner I can assist you.
Best regards,
Peter
Jan 01, 2013 | Yaesu FT-840 Owners Manual
I have a PC 78XL CB radio and it is on but cant hear nothing ,volume is turn up
Make sure squelch is turned down enough---if meter shows signal and no audio the internal speaker may be bad (plug one into external jack on rear of the radio).
If the radio transmits and shows it (or someone can hear when you xmit) the problem is in the audio circuit of the radio.
Check internal/external speaker AND SWAP THE MIC as a mic with a broken wire inside or open element as well can cause this.
May 22, 2012 | Uniden Pc-78xl 40-channel Pro Cb Radio W/...
Yeasu ft840 overload +12v,readout still good
You can replace your audio and receive transistors with a new one or a compatible one and be back on the road again. the transistors are available from all ham dealers and are normally not too expensive.
do not try to fix something that ain't broke. if it is working, leave it.
Oct 12, 2008 | Computers & Internet
T5710 Will Not xmit, etc.
I know you say your batteries are good. However, the symptoms you are describing would indicate a bad battery. Just to be sure, you might swap the batteries between the units and see if the problem moves with the battery. If not, you are correct, the batteries are good.
The next issue would be an internal radio issue, such as the unit has gotten wet or moist, and corrosion is beginning to form on the board. OR it is possible you have a hairline crack in the component board and this is causing some of the traces to make a poor connection.
FYI: It is common with these smaller types of radios for people to put them in their back pocket and sit on them. This will many times cause hairline cracks in the component board, or will cause small components to pop off the board.
Aug 15, 2008 | Motorola T5710 (22 Channels) 2-Way Radio
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Radio Communications Logo
461 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
