My TV does not respond to the remote. I can only turn the tv on and regulate the sound by pushing the bottons on the TV
  • 6,993 Answers
IS it a universal remote? If yes, remove the battery, wait for 10 seconds or more, fix the battery back in and re-register the remote with the TV by entering the code. But it the remote works with the TV without code, try again. If this doesn't fix the problem, please read further.
Try the remote with new batteries, ff new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
I hope the above makes sense to you.....
Good luck.
Posted on Apr 04, 2011
    Problem Solver:
  • 18 Answers
Can try search new remote on : www.remotes.lt
Posted on Apr 08, 2011
Soniq qv420ph no display
It sounds that the start signal does not comes from its main digital board to its main power regulator board. There is nothing a user can do with this fault. It will be best to contact any service technician. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 17, 2013 | Televison & Video
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
Sound control or lack thereof
You have a corruped EEprom. A very common problem for this TV! See a tech...there are six different EEproms for this TV and he will have to read IC001 and IC 1001 to find the right EEprom!
Jan 23, 2010 | Philips Magnavox 27MS343S 27" TV
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
Need code for programming rca tv wiht a sony
find the correct code automatically.Turn on your device.
while pressing SET botton press POWER, and release them ,then press CH+,then release it
Then press POWER repeatedly untill your device responds.don't go too fast.
When it responds press ENTER to store the code.
Oct 14, 2009 | Sony RM-V202 Remote Control
Need operating manual
if you are asking about the ” innovage” large tv remote… you do not need a code booklet.
maunally turn your tv on
point the remote at the tv
push ” code search”
a red button will blink
push the ” TV” button
then push the upper right botton with a circle and line on it…
the red burron will blink during each push…
at some point the tv will turn off…
push the “enter” button
the tv will then work with the remote.
it it takes too long to catch so to speak…
do not turn the TV off…
during the process… go ahead and push search code again..then TV
then on/off botton sometimes this speeds up the process.
i’ve found every once in a while the large remote stops responding to the on/off button…
just repeat the steps.
We hope this helps please rate/vote for me if it does thanks
May 09, 2009 | Televison & Video
Need help programing a RCA NITEglo remote cantrol
This remote was also supplied by RCA for their VHS player, model # VR629HF.
The instructions to program it can be found in the user manual for the VHS player:
http://www.retrevo.com/support/RCA-VR629HF-VCRs-manual/id/19241ag112/t/2/
1-Turn on the TV
2-Find the brand and code number(s) on the code list on the next page
3-Press and hold the TV button on the remote.
4-Enter the code from the code list.
5-Release TV, and then press CHAN up or down. If the TV responds to the remote commands,the remote is programmed.
6-If the TV does not respond, repeat these steps using the next code in the list.
Nov 14, 2008 | Televison & Video
Ge universal remote
HERE IS THE PDF LINK FOR THE ORIGINAL FOUR DIGIT CODES INCLUDED IN THE PACKAGE AT THE TIME OF PURCHASE.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
Feb 25, 2008 | GE RM24912 Universal Remote Control
Orion 27" TV - no sound
hi there, maybe you touch someting at the remote, try to experiment the bottons until it work, if still same problem, you have an amplfier section problem, test the speakers, some parts at the amplifier section. ty
Dec 26, 2007 | Orion STV2763 27" TV
Televison & Video Logo
475 people viewed this question
Top Televison & Video Experts
Electro Med Services...
