Question about Air Tools & Compressors
Graco ultimate max11 490 paint sprayer does anyone know how it works because i have no instructions
    Problem Solver:
  • 14 Answers
Here you can find manuals for your Graco sprayer: http://www.graco.com/Internet/SiteSearch.nsf/Search?OpenAgent&Mode=M&Query=Ultra%20and%20Max%20and%20II%20and%20490
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Posted on Jun 21, 2011
Graco XR7 motor won't run. Worked fine then quit. Now hums barely
Feel free to contact Graco Techinical Support at http://www.graco.com/us/en/customer-care/technical-support.html
Mar 19, 2016 | GRACO INC Magnum Pro X7 Airless Paint...
How do I find the serial number on a Graco RTX1250
It will be on the frame, in a place where it is not likely to be splashed by material of damaged. If you are looking for parts, the part number of the sprayer is more important.
Sep 25, 2013 | GRACO INC Drywall Texture Sprayer Texspray...
390 graco airless spray painter manual
Go to Graco's website at www.graco.com/us/en.html. Under the customer Care tab you can look for Instruction Manuals. Search on your model number and you'll get a list of files that refer to your model. Usually the manual and/or parts breakdown are in the first two or three files.
Aug 20, 2012 | GRACO INC 390 Airless Paint Sprayer 253958
Graco Magnum XR5 electric airless sprayer won't start
It could be something as simple as you have the pressure turned down so low it won't appear to be working try to turn the pressure up and see what happens.
The worst thing could be you did not clean the sprayer out properly and now the paint has dried and the shaft is frozen to the packings and the other internal parts of the your sprayer.
Jun 27, 2012 | GRACO INC Magnum XR5 232740 Paint Sprayer
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Spraying kitchen cabinet doors 40 degree weather airless graco sprayer enamel water base paint at first finish is great then bubbles start to form
first problem is the waterbase paints ( ****) the other is how did you mix your paint , you cam trap air in the paint if you padle or stired it without a shaker mixer air will gas out of the paint, tofix this use a foam brush to flaten air bubbles
Jan 23, 2011 | Air Tools & Compressors
Need to repack pump on graco gm5000 gas paint sprayer
you can put your model in or if you have a part # you can enter it into one of the fields eventually you will fing a parts diagram for your unit.
Jun 02, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
853 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
