Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
I have 706 Farmall tractor with the D310 engine and TA. When I baught it the transmission fluid was all milky with water and the TA and power steering did'nt work. So I changed the oil and filter and everything seemed to work fine,but now several weeks later it started to act up again. When I first start it I won't have any steering and TA is stuck in low side and in one occassion the 3 point arms didn't drop. Usally when i drive it a while and get it warmed up it works again. The oil is slightly milky again from old oil contamination. Thanks for any information. Moses Zimmerman
  • 18 Answers
Change hydraulic filter again and probibly the oil use ahigh quality hydraulic oil like Case-ih hytran fluid this oil has a high moisture retention factor be sure to drain all the cavitys 5 plugs total and let them drain completely before refilling
Posted on May 08, 2011
Where is transmission filter located on international 756
I t is behind teardrop shaped cover below r ight hand brake drum.
May 20, 2014 | Farmall IH Tractor 706, 756, 806, 856,...
Milky hydraulic fluid
if it looks white like milk it could mean that there is water in it.
Apr 06, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
806 hydraulic drain and filter I need to change the oil as it is milkey and I am not sure where they are
this will help but if you hook back up to the equipment that you use it still has the milky in it and ity will mess your good oil right back up
Jul 03, 2011 | Farmall IH Tractor 706, 756, 806, 856,...
806 internatoinal grinds when you try to go from low rangr to high range,is it likely that the transmission is bad?
the first thing to remember is that this transmission has straight cut gears that shift with a slide collar the tractor probabably will need to be brought almost to a complete stop to shift. if it continues to grind check clutch pedal adjustment and ta dump spool adjustment . then adjust trans brake . at1000-1200 rpm it should drop into gear with very little or no grinding
Feb 05, 2011 | Farmall IH Tractor 706, 756, 806, 856,...
F 806 rear lift stays up, unless tractor is off....
i would think that the lift control handle is stuck in the lift position, and when the engine is on the fluid will bypass the control handle and thus raising the lift. replacing or repairing the control should solve the problem. good luck
jim
Oct 16, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Where is hydraulic filter located on IH 706 Tractor?
right hand side -teardrop shaped cover bolted to side of transmission should only lose a gallon or so of oil when changing
Aug 06, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
I have a 1967-706 Farmall IH splitting a transmission
you must remove the plate from the bottom of the transmission. Look for a shaft that goes from the rear through a gear. Remove snap ring from in front of gear and it should roll apart then. On reassembly be sure to change gasket and all o rings to prevent hydraulic suction leaks
Jan 18, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
1,290 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Tom Chichester
Rod Newman
Rod Newman
Level 1 Expert
Are you a Farmall Toy Expert? Answer questions, earn points and help others
