Question about Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058
I have a miller spectrum plasma cutter. When I turn on the power the green light stays on for about 10 seconds and then starts to flash. The torch will not operate.
4 Suggested Answers
SOURCE: can i plug my miller spectrum 1000 plasma cutter
no you idiot! the plug is different & even if you could somehow, its half the power output. Your plasma welders for the matter, have whats called a duty cycle, which plays into effect.... electrical load level....ect.
HOWEVER-- you can plg ito the same outlet as your stove, washer & dryer plugs. DON'T BURN YOUR HOUSE DOWN, The wife will kill you!
Posted on Sep 05, 2010
SOURCE: how much does a circuit board cost for a miller
depend the circuit boar but is be twin 500 and 700 usd
Posted on Feb 08, 2011
  • 5 Answers
SOURCE: miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Posted on Nov 27, 2011
Miller 375 x-treme fires about 30 seconds then stops it doesn't stay running, no trouble lights...
Have you watched to see if the pressure light comes on right before shutdown? If so you may need to add a tank right next to the torch base to address the pressure drop assuming your air source is able to deliver adequate volume to the cutter continuously and you currently have more than 25 feet of hose between cutter and compressor. It might not hurt to check the internal filter as well.
Dec 29, 2011 | Miller Spectrum 375 X Treme Plasma Cutter...
Miller plasma cutter spectrum 625
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Green light flashes
always remember the ground...
have a big air supply. small compressors can not keep up and machine stops cutting.
Nov 24, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
All lights correct, no start
loosen the retainer cap and twist the consumables and retighten
Apr 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
Pilot wont lite. miller spectrum 701
check the cables in the plasma torch.
If the problem continues, theres no enough power to start it.
Jan 04, 2010 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
I bought a used miller spectrum 625, can put on
The consumables on the torch head could be incorrect or not installed correctly. check these.
Sep 28, 2009 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Miller 2050 that will not spark.
This is relative to 3 causes , contol board , pwm board or torch
Feb 28, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058 Logo
115 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
