Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Circuit board Where did you buy the board for the Samsung TV?We tried replacing th IC's but we get nothing on the TV now. Thanks for your help
Go to PartStore.com.
Posted on Aug 21, 2008
No red light not power at all
Easily done: Your Power Board...
(visual reference only
(to see what you are looking for))...
>> but it is VERY IMPORTANT to verify
the CIRCUIT PACK number YOURSELF...
I can-not sympathize with you enough...
(self interest: your techy loses $$ when you win).
TH 50PZ800U power board eBay
I watched a CIRCUIT CITY "contract techy"
destroy our first MONGO (52" ) Flat screen...
(a supposed professional).
Even though that was ALL at CIRCUIT CITY'S
expense... (now expectedly closed in our area)...
I was very SAD to watch(albeit predictable).
If you want to get in with a chance of winning
you need only put every wire cable & screw
EXACTLY back as it was ... TAKE PICTURES
and CAREFULLY review the before starting.
Force NOTHING...
and
WEAR an anti-static wrist-band WHILE HANDLING
every semiconductor board YOU CARE ABOUT.
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Shop Jimmy is the premier circuit pack source...
TV Parts Universal TV Stands DLP Chips ShopJimmy
I buy all my packs from eBay ...
Hope this helps
Carnac the Magnificent
Nov 03, 2017 | Panasonic Viera TH-50PZ800U Plasma TV
Phillips TV
Dear Sir/madam,
You have defective filter capacitor/s in the vertical circuit. Or defective solder connections on the pins of the vertical ic.
If you can bang it on the side & get the picture back up, then you probably have a bad connection in the vertical output circuit.
It should just require resoldering the printed circuit board & I would guess right at the output I.C.. Replace the IC with authorized service centre.
Thanks
Good luck
Don't forget to rate the solution
Jul 20, 2008 | Sony Televison & Video
Please what is the factory reset for samsung tv.Modle Cs-21z58ml.
samsung tv MODEL CS-21Z58ML.no picture and low brightness problem has been re solved by replace the crt .if you found 4voltage for heater 190volt for scren still no picture you have to replace crt.but some times might be the micro chip on the circuit that its not pushing up the RGB's colors but most and common problem is CRT board.if you'll try to replace the transistors or ic.it will not change any thing.so guys letme know if you fixed it at costerntine@gmail.com thanks
Mar 07, 2011 | Samsung LN-T3253H 32 in. LCD Television
Sony kp-51 ws500 rear projection tv. when turn on tv there is 3 duplicate images overlayed...green, white, red. looks like I am watching an old school 3d movie, but without the glasses. i already took the...
The problem is your convergence circuit board gone bad. This is commonly caused by shorted/open IC on that board. First try to spot if there is a bad solder joints and resolder it. If nothing replaced the convergence IC. Also check the resistors around.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 13, 2011 | Sony Televison & Video
I have a samsung lcd ln40a330. When I try turning it on it does nothing. Is there a fuse to it.
Yes,the fuse in the power supply board,that the board,where the power a/c cord plug into it.Check ur power source?Yes,than the tv power supply board is dead.These modern circuit boards design never kill the fuse that easy.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 28, 2010 | Samsung LN40A530 40 in. LCD TV
Samsung hl-r6178w 3 blinking lights
The power board ic converter is dead.
U can tries to go to the web buy the part and replace it yourself.Or hire the repair man part and labor $575
Aug 13, 2009 | Samsung HL-S5087W DLP TV
Getting sound from center channel only on my JVC-TH-M505
check the jack female and male jacks r allright
the connection is correct u need to check these first
then u if nothing works use the fuse replacement
Mar 07, 2009 | JVC TH-M505 System
Have a philips magnavox 8p6044 c102
Hmmm... I dont know where to find those CTR Circuit boards I'll post my general post for you about what I know it has links to the manual and some other sites it may help.
how bad is it burned, did some chips go or just the copper circuit board tracers. you can use circuit board wire and solder it from point to point,
I had somewhat of the same problem with my IC board, I had a bad portion of the board where I had to build a new copper routing with circuit wire, the copper burned off when the resistor failed, you may need to do a little Frankenstein work on your board as a last resort... remember use a low 15 watt soldering pencil, use leaded solder, and USE flux!
however with all my work, I got it running but the IC board is still not running perfect. if you decide you cant fix the TV I would love to buy your IC convergence board from you.
GOOD LUCK! hope I helped...
GENERAL POST WITH LINKS BELOW.....
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Samsung HL-S6187W 61 in. HDTV black screen on the right side
If you found a bloated capacitor on the circuit board, that one needs to be replaced not the board. You can see the part number on the capacitor itself. Also please look for any burned IC and neighboring components. If you found additional burned components, it also need to be replace. Contact a pro tv technician to replace it.
Order parts here:
http://www.partstore.com/Sitemap/Generic/Television+parts/Television/Television+parts/television+parts.aspx
Aug 30, 2008 | Samsung HL-S6187W 61 in. HDTV
Power circuit board needs to be replaced
Samsung parts
http://www.partstore.com/Part/Samsung/Samsung/
Jan 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Henry  Thomas
Henry Thomas
