Question about Sport & Outdoor - Others
I have a 2000 600cc Grizzly. It was running great last week, now it`s not. The neutral light only comes on when the bike is runnin, and the headlights are on. The electric start doesnt work any more, and the battery keeps draining within 2 days. Soo frustrating. Any ideas?
    New Friend:
  • 98 Answers
Even though you have a full battery do a load test on the battery. There could be dead cells in the battery this would have the effect. If you have dead cells then you would not have enough Cold Cranking Amps to start the vehicle.
Posted on Apr 04, 2011
  • 2 more comments
  • jarrod_marsm Apr 04, 2011
    Yeah, I hear u. But this is a new battery, and a new one. I have been told is not the stator/altenator, or the battery. The mechanic at pro cycle thinks it is a ploblem with the wiring, like a short or something. I know nothing about these machines... Thanks for the helpful info my man~~
  • Al Wolfy
    Al Wolfy Apr 04, 2011
    Then check all the ground wires. If you have a loose ground this will cause a lot of problems like: Hard Start, Lights Dimming and not running right & More.
  • Al Wolfy
    Also Check for corrosion on the wires or battery terminal.
  • MrSlugbait Apr 06, 2011
    Just to narrow the problem down a bit, try unplugging the regulator/rectifier and see if the battery still discharges over a short time, the diodes in the rectifier can leak backwards even though the unit still performs normally when the engine is running, (this problem can often be diagnosed by the reg/rec unit getting warm or hot when bike is left parked up). its worth noting that the charging system remains in circuit, ie connected, even if the bike is switched off, and relies solely on its diodes to stop reverse current drain, hope this helps.
2000 yamaha grizzly issues when warm
Check oil level capacity, to ensure in specs. Check spark plugs, ensure its clean and correct plug for your quad.the only other could be is ign coil breaking down when warm. Check fire at plug when this happens. First ensure oil level is correct. Make sure your electric fan is on when bike is warmed up.
Nov 07, 2017 | ATVs
Why won't my grizzly 660 go into neutral so I can start my bike
K, Linkage probably needs adjusted.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2006 GRIZZLY 660 MOD HELP and SHIFTER ISSUES
http://www.yamaha-motor.com/assets/service/manuals/2008/lit-11626-21-03_griz660_all_1498.pdf
Mar 20, 2016 | Yamaha 2004 Grizzly 660 Auto 4x4
When I turn key on I have head light but no instrument lights and it won't turnover
I would suggest you check the wiring loom around the headstock as you were able to cause symptoms when moving the handlebars. You may have a broken wire inside the loom so you will have to open it to inspect it.
Apr 09, 2015 | Power Motorcycles
Wont start at all
If you have no light you can't even hot wire it sounds like the ignition switch is bad in the start and run positions.
Jan 30, 2014 | 2005 Yamaha YZF-R6
1998 cbr 600 f3 neutral light wont come on and bike wont start with kick stand down
Looking for some help got my 98 cbr 600 f3 a week ago parked it at my grams it rained bike fell over neutral light wont come on and won't try to start with the kick stand down please help
Jul 13, 2013 | Motorcycles
Friend took delivery of his brand new YBR 125 last week. Neutral light is on yet bike is obviously still in gear as bike pulls forward/stalls when he releases the clutch lever. Have not addressed with...
Could be a bad neutral switch, shorted or mis-connected wiring. This should be covered under warranty by the dealer at NO charge. Hope this helps!
Sep 19, 2010 | Yamaha Ybr 125 Motorcycles
A FRIEND GAVE ME A 1982 SUZUKI GS550L WAS PARKED FOR OVER 5 YRS + AND IT STARTED WITH A JUMP START I THINK THE BATT IS NO GOOD DONT HOLD CHARGE WHEN ITS RUNNING , THE FLANGES HOLDING THE CARBS LEAKS...
The neutral safety switch is out of adjustment. Most bike won't start unless it is in Neutral or the clutch lever pulled in. Get a new battery and charge it up full. The intake boots need to be replaced or it will run lean. That is why you need to chock it to get it to run.
Oct 18, 2009 | 1982 Suzuki Gs 550 L
Bike in neutral will not start
could be kickstand switch or neutral switch. also check kill switch. starter relay should be under seat by main electrical harness with rest of bike relays.
May 26, 2009 | 2006 Yamaha V Star 1100 Classic
Sport & Outdoor - Others Logo
118 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
