Question about Lexmark Z611 InkJet Photo Printer
Lexmark Z611 Printer
I installed a black cartridge 17 and printer will not print paper comes out blanks even though it says printing has started and then completed
  • Anonymous Aug 20, 2008
    Printer prints black ok but not color? Was working the other day.
  • 39 Answers
First, try to clean the nozzles on it. That may or may not work.
Otherwise, if you bought it new from a store, return it and get another one, sounds like the cart may be bad. If you bought it used or refilled it and have refilled it several times, the nozzles or other parts may be worn out. In that case you'll probably have to have to break down and by a new cart.
Posted on Aug 07, 2008
SOURCE:
My lexmark z611 only prints blank pages with nothing on them, i bought a brand new ink cartridge that is black ink for it and it says it is low on ink for some odd reason but when i print things in color...
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
May 15, 2011 | Lexmark Z611 InkJet Photo Printer
Printer prints blank pages
Inkjet print heads have a tendancy to clog with disuse. If your cartridges include the heads, you can sometimes use a bit of alcohol to loosen the blockage. Soak a bit of paper towel and place the cartridge on it for a while. Then replace the cartridge and do a head cleaning.
Jun 18, 2010 | Lexmark Z611 InkJet Photo Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
My printer is printing blank pages What is wrong?
1. Remove the cartridge or cartridges from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridges back into the printer.
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Disconnect the power cord from the back of the printer.
2. Press and hold the button on the printer panel.
3. Reconnect the power cord and keep holding the button on the printer panel until the printer starts to pull paper.
4. The printer should now print a test page. Please note that the test is continuous. To stop the test, disconnect the power cord.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Apr 16, 2009 | Lexmark Z617 InkJet Photo Printer
Will not print any black Z611 Lexmark Printer
It's possible the black nozzles may have become clogged or the black cartridge may not be properly seated. Recommend you contact technical support via www.lexmark.com.
Jan 22, 2009 | Lexmark Z611 InkJet Photo Printer
Lexmark Z715 will not print but computer says it is printing
The Z715 needs a #50 black ink cartridge and a working color cartridge to print. To check if there ios ink coming out of your black or color cartridge touch the bottom of it to a paper towel and if you see a solid black blob or 3 blobs of Yellow, blue and red for the color then your problem is else where. If U are printing stuff from the internet sometimes the printer will try to use the color cartridge to print this so even though the black is working it comes out blank if the color is dry
Jan 16, 2018 | Lexmark X4650 InkJet Printer
Lexmark X1270 Not printing.
Did you put the right numbers of the cartridges?
Sep 30, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer doesn't print even with new ink cartridges.
turn the printer i turned on and Press the cleaning button ,. Cleaning takes about two minutes, the printer makes some noise when it finishes you run a nozzle check for print quality and reset the cleaning cycle.
load paper . go to the printer menu as follows: click Control Panel, and then double-click Printers. Select the Epson printer if have more than one printer is installed. Click File, click Properties, click the Utility tab, then click the Nozzle Check icon.
The printer will print a Nozzle Check pattern in black, and in cyan, magenta, and yellow. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If any dots are missing, clean the head again.
If your software is different, and does not have these options, you can do it this way:
1. Same as above.
2. Same as above.
Turn off printer and computer. Disconnect interface cable from printer. Load paper. Hold down the load/eject button and press the power button to turn on the printer. Release both buttons.
3 Same as above.
4 Turn off printer and reconnect the interface
May 17, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark printer
Lexmark technical support should be able to help resolve this problem, assuming the cartridges were Lexmark branded. Contact information is on www.lexmark.com.
Feb 13, 2008 | Lexmark International Z611 Printer
Open Questions:
See all Lexmark Z611 InkJet Photo Printer Questions
Lexmark Z611 InkJet Photo Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
