Question about Hunter 25658 Lancaster Antique Black Ceiling Fan
I have the Hunter/Lancaster fan---the shades have become brittle and I need replacement shades for it. I have looked everywhere and cannot find them since theyhave a screw in plastic part to hold the shade in place. Please help--the fan workd great --just need the shades
hardrocko
  • 1476 Answers
SOURCE: 3 speed Hunter Fan only has 2 speeds
Assuming that the unit was wired properly from the factory and without being able to look at the switch I would have to agree that the switch is bad. The different speeds are obtained by having a different winding for each speed. If the unit was wired properly at the factory and never had three different speeds then the switch is not rotating between all the contacts. The switch should only be a couple of dollars and would certainly be a cheap solution to try. You can check the existing switch by removing it from the circuit completely and checking the continuity with a DMM from the input to each output as you switch it. Continuity should move from one to two to three. If not the switch is bad. If the switch checks out OK then you have a bad winding in the fan and probably need a new unit. Good luck.
Posted on Jul 12, 2006
Rube69her
SOURCE: Glass Shade wont come off
The same thing happened to me, you put them on two tight. just right now i was going to take mine off so i could let u know which way to turn it. but can't take it off and i just put it on last night, & not too tight. i just remember that i have an xtra one, okay i got it it's counter clock wise. you're going to need someone to help you hold the light kit fitter assembly while you turn it. careful not to strip the light kit fitter assembly. mine rotates both ways now because when i tried to take it off it would turn so mabybe it's the other way, and nothing. then i got **** & started to used more force, back and fort, by myself even with the help of my friend it was a ***** to get it off. good luck. Rube
Posted on Jun 27, 2009
  • 80 Answers
SOURCE: Glass replacement for Hunter fan
I spoke to the people at hunter, they have two styles available , neither match the existing one that I have. They said I could send mine in and they would replace it possibly if it was a manufacturer defect. I think it is a design issue. Glass is heated and cooled repeatedly and the base becomes brittle, mine fell and put a big dent in my table. good luck finding a replacement if you dont like what they have.
Posted on May 16, 2010
  • 436 Answers
SOURCE: we have a Hunter 20461
cannot find good picture. you will need to:
call 888-830-1326 for assistance.
Posted on Apr 10, 2011
  • 257 Answers
SOURCE: 8 year old model has metal lamp shades one of
You need to remove the entire light kit first by removing the 3 screws around the housing, one completely and just loosen 2 of them, turn slightly counter clockwise and pull down to release, depress wire harness clamp and pull apart, now you can work on the fixture.
Posted on May 17, 2011
How to I open the light figure to replace the bulb?
usually three screws just above the shade that drop into a recess around the shade. Support the shade and undo them by hand. They should be finger tight. You don't need to remove them all the way. Dont overtighten when you put them back or you can crack the shade.
Apr 24, 2016 | Hunter Fan Fanaway Ceiling Fan - 4 Blades...
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Jul 09, 2015 | Hunter 52" Ceiling Fan With Light And...
Need a replacement capacitor
Voltage rating doesn't matter. 250v or 330v will work.
If this is really a 2 speed original, with the 2.5Amp motor... it will NOT have a capacitor as the motor is a shaded pole unit. The three speed electrically reversible fans, have a capacitor, which can either be in the switch housing/ oil reservoir, or the top of the motor housing, depending on year of manufacture.
Oct 24, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hi, hunter fan glass replacement can be found at amazon, take a look here and chose: Amazon com hunter fan glass replacement. Regards. Donald
Jul 10, 2009 | Dryers
Hunter 25658 Lancaster Antique Black Ceiling Fan Logo
260 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
