The lights 3h 6h 9h delay,ready and spin stay on. ive tryed changing the programe but nothin seems to happen the door all so doesn't open how do i fix this problem please. would be great if u could get bk to me asap as i would like to do some more washing Ive drained the water to!
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
gittos73
  • 244 Answers
SOURCE: hotpoint washing machine belt come off
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Posted on Jan 27, 2008
  • 25 Answers
SOURCE: beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Posted on Jul 16, 2009
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
Macmarkus
  • 2605 Answers
SOURCE: Washing machine has stopped w/ water still in drum
Hello and welcome to fixya.
The "E13" error code on the WFMC series Bosch washer`s refer to a drainage problem as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely.
You haven`t mentioned if you`ve checked the pump...just hoses as you did mention.
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
  5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.
  6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
  7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
  8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
Posted on Jul 08, 2010
4h and 6h delay lights on. Door not opening
Call the manufacture tech support line or Google it on line and see what info comes up put in the model make of washing machine
Sep 01, 2015 | Washing Machines
How do I reset the program. It will not start
on ur last wash did it spin ok or where the cloth a bit wetter than normal
Jan 25, 2015 | Candy Washing Machines
Dishes not drying, greasy items not clean
You are alomost there. Yes these are some common issues and get resolved only by replacing the heating element.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | LG LDF6810ST Stainless Steel Built-in...
Dish washer does not turn on CL light stays on when reset count down 6 appears then goes to CL
Hello and welcome to Fixya,
I have a ton of service info on Bosch so it`s best I post you an exert from the service pdf`s I have on my PC which will explain the meaning of "CL" and then go from there. This is not a common indication of a control problem, but it could be a problem with the plastic casing which houses the control, we`ll deal with that later.
I`ve underlined the section pertaining to the "CL", this is for the SHU68** dishwashers only.
TO OPERATE:
First depress the On/Off Button until it locks in place.
Once the On/Off Button is depressed the LED above the previously used cycle will illuminate.
To change the cycle, simply press the desired Cycle Button twice. The LED above that cycle will then illuminate.
The Cycle Countdown will display an approximate run time for the cycle chosen.
This run time will depend on incoming water temperature and the turbidity of the pre-wash water.
Note: It is normal for the Countdown Display to remain at a time increment for more than one minute, or skip a time increment depending on the calculations of the Control Unit. Also, with continued use the Control Unit will learn the wash and temperature patterns for the most commonly used programs and will then reduce the overall start and running times.
At the end of the cycle the display will show a CL, indicating that the cycle is complete.
**TO CANCEL A CYCLE:
Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
DELAY START:
The Delay Start feature allows the unit to be delayed for up to nine hours. To program, start the unit as described above, but after selecting a cycle push the Delay Start button. The display will show a 1h, or one-hour delay. Continue to depress the Delay Start Button until the desired delay time is reached (up to nine hours, 9h).
The unit will begin automatically once the delay time has elapsed. To reset the delay, press the Delay Start Button until it reaches 0h.
TOP RACK ONLY:
The Top Rack Only feature can be used in conjunction with any cycle. To active, press the Top Rack Only Button after selecting a
cycle, the Top Rack Only LED will illuminate and all water will be diverted to the upper wash arm for the complete cycle.
REFILL RINSE AGENT LED:
The Refill Rinse Agent LED is activated via a Reed Switch on the Detergent Dispenser, Section 4, Fig. 8-3. The LED will
illuminate when the Rinse Agent Dispenser is empty.
Service note: The Refill Rinse Agent LED will also illuminate when the dishwasher door is opened and then
closed even if the Dispenser is full, but will only remain lit for a few seconds.
“F” CODE:
An “F” in the display window indicates a filling fault.
Please note: If the door is opened during the cycle, the On/Off Button will be reset to off and must be depressed again to re-active the cycle. The cycle will resume from where it left off.
Now that you are equipped with this info, what I`d suggest is trying the **cancel option. ( ** see above )
Once you`ve tried the cancel option, select a Regular Wash and post back what happens and I`ll try to assist you from there.
Good luck.
macmarkus :)
May 14, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
GE Simon XT panel lights window, door and motion indicators
It sounds like the auto-stay arming function. Try arming it and opening and closing the door.
Feb 10, 2009 | GE Security Simon 3 Wireless Home Security...
1992 Range Rover
Yes, it sounds like it burned the contact points in the dome light delay. They were never really designed to have the lights left on for that long (and being 13 years old, it has already had some usage before this)
The part you need is PRC9948G (I would double check that with your dealer).
It is the delay courtesy relay.
Sep 06, 2008 | 1995 Land Rover Range Rover
Re Instructions manual
You can download instruction manuals for Indesit products from the http://www.indesitservice.co.uk/hs/pages/manual/manualSearch.do
page on Indesit's service website.
Grame
Apr 11, 2008 | Indesit W 123 Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
354 people viewed this question
Top Washing Machines Experts
