Question about Panasonic TH-42PRT12U 42 in. TV
I have a th42prt12u and the unit is locked. Nothing is working i would like to know what to do to unlock the unit
Please help me to unlock my phone
You need to get the unlock code from the service provider previously associated with the phone.
A brand new phone out of the box with no carrier affiliation should not be locked. If it is double check the manual that came with unit for remedy. If nothing I would return phone and exchange it for a properly working unit.
Oct 30, 2015 | Cell Phones
My avital 4103 will not lock or unlock my doors on my 01 crown vic
It sounds like you wired up the door locks incorrectly. You need relays to control your doorlocks. Follow the diagram in this link to wire up the relays.
http://www.the12volt.com/doorlocks/page3.asp#5w
Jan 06, 2013 | Remote Start System
Is there a way to unlock a hypercon t4205? I think Central Payment locked it. let me know.. thx
No - for security reasons there is no way to unlock it without opening the casing and that will cause the complete wipe of the firmware so no way of using it after wards.
The only ones that can do the unlock are the ones that put it there (in case of a software lock - the cards are no longer accepted and the unit can't connect to the network) or Hypercom themselves, at their factory (in case of hardware lock - nothing works on it).
Aug 22, 2011 | Computers & Internet
MY 1998 HONDA ACCORD EX WAS PURCHASED USED A YEAR AGI. MY PROBLEM LIES IN THAT THE DOORS LOCK AUTMATICALLY WHETHER THE CAR IS RUNNING OR NOT. I HAVE ALREADY HAD TO GET THE EXTRA KEY TO UNLOCK THE...
Ken: The locks are supposed to work the way you describe it, there is nothing wrong with the unit. Should you desire to disable it, you will lose other functions as well, such as remote unlocking. The alarm/ locking unit is located behind the left kicker panel
Jan 27, 2011 | 1998 Honda Accord
On my remote the unlock is the only thing that works. my lock and remote start doesnt work. everything used to work before i got my transmission fixed and when i got it back nothing worked and i have been...
You could try reprogramming the remote: ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off. test. If this doesn't work, try disconnecting the unit's power for about ten seconds, then reconnect and test.
Sep 30, 2010 | Car APS997A Two-Way Remote Start and...
The control panel is locked. Attempting to wash my clothes i plug in the washing machine and it says control lock and nothing else is working
Maybe their is more to it but have you attemped to unlock the controls..on the lower right side of the control panel there is a button for the end of cycle signal (volume) if you push and hold down on this button for 3 to 4 seconde it will lock all the buttons and the unit will do nothing ,if there all ready locked push and hold this button for 3 to 4 seconds and they will unlock and unit should work as normal I hope this will help If you have a different concern after this write back and we will see what else we can do to help you out...good Luck
Sep 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I want to unlock my door
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
How to unlock maps after re-installing them?
I ended up in the same situation and called (800) 421-5013 for help. The gentelman who assisted me said that how the DVD holds the same data as factory Sanyo 4050 GPS and upgrading has locked your device. To resolve the discussed issue one have to delete everything (plug-in your device via USB cable --> My Computer --> Removable disk) and install fresh copy onto your navigation device via that DVD.
Tried it with NO @!@ JOY
Dec 13, 2008 | Sanyo NVM-4050 GPS Receiver
Panasonic TH-42PRT12U 42 in. TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
