Question about Dryers
After about ten minutes it starts squeaking real loud!!!!!!!!! It runs, heats up, and tumbles just fine. The belt doesn't appear to be loose either. I cleaned out the fuzz bunnies, and sprayed a little wd-40 around the pulley, but it did not fix my problem!!!!! Any ideas, short of a stick of dynamite!!!!
    Genius:
  • 1,466 Answers
Its the Jockey pulleys that are worn they sit between the motor shaft and belt. they tend to dry out and squeal.....
Posted on Apr 04, 2011
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
I replace the front drum bearing and 4 glides the drum turns fine and works good but after about 5 minutes when my ge gas dryer gets hot it starts squeaking real loud again please help
It may be either the idler pulley which rides against the belt to keep it tight or the Teflon insert into which the shaft of the drum is inserted.
Feb 26, 2011 | Dryers
When I first start my dryer, it squeaks real loud for about ten minutes, then stops. It drys the clothes without any problems.
drum rollers/glides may be the idler arm, if is located next to the motor:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 23, 2011 | Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Proline tumble dryer TDC6A makes a loud grinding noise.
Howdy: There is a spring loaded belt tenioner that holds the belt in place. They are plastic with steel bearings. They do go out often do to the surround heat in that area. Good luck - Doug
Dec 09, 2009 | Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Makes squeaking noise after running for about 10 minutes
Replace the dryer drive belt and the dryer tub rollers.
Mar 01, 2017 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
