Question about Hotpoint Aquarius WF000 Front Load Washer
I just cleaned filter and now the drum is not turning. The machine is making lots of noise but not doing anything. Do I need to reset something?
    Genius:
  • Hotpoint Master
  • 1,461 Answers
Check the plug /harness to the motor has not come loose....
Posted on Apr 04, 2011
Why is my washer making noise like the drum is out of line or something is stuck in the track
Is the pump running all the time
trying to remove the water?
Under the machine maybe a diagnostic
manual
You can remove the front cover on some
machines,probably have to tip it over to work on it
You need that service manual
Jul 15, 2014 | Kenmore HE2 Plus Front Load Washer
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | LG DLG5988 Gas Dryer
My servis washing machine makes a loud grinding noise when the water drains whilst drum turning.
could be something in the pump as opposed to drum bearing fault....Try cleaning filter/check pump blades.....
Feb 24, 2011 | LG WM2077C XL Front Load Stackable Washing...
Has been working as usual until today .Scuffing/ scraping noises when drum is turning
Check for pin, or other item caught in a hole in the tub rubbing on the outer tub to make noise as the tub turns.
Feb 22, 2011 | Washing Machines
Overload affected performance. Even when only got 1 item in machine. Makes lots noise when spinning and inner large plastic seal looks like something caught on it and shredded some of plastic.
this fault can be caused by the drum halves becoming tight .they move together due to limescale deposits between the drum spiders. the noise is most likely a failing drum bearing
if the plastic seal is damaged then it will need a new drum assembly
they are no longer available from dyson due to supply problems
you may be able to get another machine from ebay and fix yours using parts from each machine to make one good one
Nov 10, 2010 | Dyson CRO1 Front Load Washer
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine is making an awful noise when its changing direction on the drum motion and changing programme. its sounds very much like some sort of ball baring has come loose. - what doi I do please...
put the machine onto drain position if it still makes the noise it is something stuck in the pump check and clear filter if makes noise only when drum turning then is highley suspect bearings have failed.
Jun 02, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Jan 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine
It might be a bearing, or it might just be something inside the drum!
If the machine is not exceptionally old it shouldn't be a bearing.
It might be limescale!
You can access and inspect the drum from the outlet.
Heres what to do:
Disconnect the machine from the mains and the water supply and pull it into a clear area.
Put a thick cloth on the floor and gently lay the machine on its left hand side, looking from the rear,
Undo the small panel on the back and you will see the black rubber concertina hose, pressure chamber and pump, which are now all easily accessible from the rear and the botom of the machine.
Undo the circlips with a screwdriver and pull the hose away from the drum. You will now be able to see the element and the inside of the drum.
Check it for debris and limescale.
At the same time clean out the filter with its "ping pong ball" and plastic pressure chamber.
THis will clear out any loose items and let you check to see if the drum needs descaling.
Job should take about 20 minutes!
Feb 19, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
