Question about Bell Sports Bell Deluxe Patch It Tube Repair Kit
I just want to know how to make the brakes (quick) release so I can remove my rear wheel
    Brigadier General:
  • 8,546 Answers
You don't say what style or brand, but they're mostly covered here...
http://www.parktool.com/blog/repair-help/categories/brake-service-and-repair
Posted on Apr 05, 2011
Testimonial: "Thank you so much. Your article told me everything I needed to know! I found the pictures extremely helpful. Your'e now on my favorites list!"
How do I release an engaged parking brake when the cable I usually pull to release the brake is broken?
I should have disengaged when it broke if not it is jammed some where and not releasing so raise the rear and follow the brake cable to the rear axle and remove cable try rotating wheels if no joy remove wheels and tap brake drums and try rotating drums if still no joy try stripping brake system down on rear axles to free up internals
Aug 26, 2015 | Cars & Trucks
Quick release bike tire installation
the pads don't need to be removed. Most brakes have a "quick release" on them. On linear pull brakes, use one hand to squeeze the two lever against the rim and with your other hand you can pull the "L" shaped cable noodle out the bracket and this releases the brakes. (you can also let the air out of the tire and install the wheel then reinflate the tire once you have it back on the bike). On road bikes with side-pull brakes most have a small lever you can flip up that activates a cam mechanism that opens the brakes up to allow the tire to pass through. Canti-lever brakes are similar to linear-pull brakes, just squeeze the brakes together and release the straddle cable. Hope this helps.
Aug 13, 2014 | Cycling
Change rear wheel on the trek scratch air 6
put the chain on front side peddal on the smallest gear.
unlock the rear wheel and tap on side wheel whit your hand.
Nov 06, 2012 | Trek Scratch Air 6
How do i change the innertube in my rear tire
I think we can get you through this pretty easy. First release the rear brake. There should be a quick release at the brake it self or the caliper (squeeze brake and turn tab if it is there) One nut on either side of the rear wheel...should be 5/8th. You don't need to remove the nut just take it to the end of the axle on either side. Push the wheel forward while holding the de-railer all the way back. This will allow the wheel to drop down. That de-railer makes it look a lot more intimidating than it is. When you go to put it back on just hold it out of your way again. Be really easy if a person had three hands but it works with two.
Aug 10, 2012 | Schwinn Cycling
Marin larkspur bike. unsuccessful in removing wheel. do not know how to move brakes (unlock?)
This is not a motorcycle! but undo the axle nut or Quick release lever and remove the wheel( if it is the rear one you have to unhook the chain as well) By the sound of it you do not have the skill level to carry out this sort of work. Brakes are a safety device so need to be looked after properly.
Feb 12, 2012 | Motorcycles
I'm trying to change my rear tire , i have put the chain in the smallest cog in the rear, loosened the quick release but the tire doesn't want to come out. Do you have to do something with the...
If the quick release is truly loose, from the rear just lift the bike by the left side of the seatstay (or what would be a seatstay if itwasn't rear suspended) and rotate the rear derailleur backward with your right hand. It should just fall out.
Google "remove rear wheel bicycle" for lots of advice in video form.
May 20, 2011 | Cannondale Jekyll 800
How do I remove the rear wheel from my bicycle? I think it has quick release but I don't know.
1. If it has quick release it will have 2 plastic levers one at each side of the wheel axle. Otherwise there will be 2 nuts.
2. If it has the levers, Pull them out from the wheel. This eases the pressure on the nuts holding the wheel on the bicycle. Turn them anti clockwise to loosen them further. The wheel will then come away from the bike frame. (If it doesn't have the quick release levers just loosen the 2 nuts with a spanner)
3. Before taking off the chain draw a diagram or take a photo of how it's setup on the derailleur so you'll know how to put it on again. Pull the derailleur upwards to release the pressure on the chain and you will be able to remove it from the wheel.
4. All that remains then is to pull the wheel out of the brake pads.
Nov 15, 2010 | Cycling
When I take my daughters front wheel off her Diamondback bike I need to reajust the front break. How can this be avoided?
By always placing the wheel firmly into the fork's dropouts and then then tightening the quick release. Adjust the brake centering and it should always stay the same UNLESS the brake centering itself is moving every time you disconnect the brake to remove the wheel. Then it gets complicated.
Look here:
http://parktool.com/repair/byregion.asp?catid=14
Aug 02, 2010 | ProMax 197NC Bmx V Type Brake Set, Rear,...
No Rear Quick Release
Some less expensive bikes do not come with quick release skewers. You just unscrew the bolts like you would any other using a wrench or socket. The will probably be really tight so you may need to bear down or use a cheater pipe. Unfortunately, these bolt on wheels tend to be solid axles and cannot take a quick release skewer. You would need to replace the wheel.
May 20, 2010 | Schwinn Miramar Women's 21Speed Bicycle
Parking brake assembly diagramneeded
Item Part Number Description 1 2553 Rear Disc Brake Caliper 2 4234 LH Axle Shaft 3 2C026 Rear Disc Brake Rotor 4 383609-S Push Nut (2 Req'd each side) 5 2C189 Rear Brake Anti-Lock Sensor Indicator 6A 3912205-56 Nut (4 Req'd) 7 2C220 Rear Wheel Disc Brake Adapter 8 1177 Inner Wheel Bearing Oil Seal 9 390317-S190 Bolt (4 Req'd) 10 1225 Rear Wheel Bearing 11B 2B296 Disc Brake Caliper Locating Pin A Tighten to 27-54 Nm (20-40 Lb-Ft) B Tighten to 26-35 Nm (19-26 Lb-Ft)
The automatic (vacuum) release-type is standard equipment on all vehicles. The automatic vacuum-type parking brake system contains the following features:
  • A parking brake release control motor (2A843) with mounting bracket bolted to the parking brake control .
  • The vacuum-actuated diaphragm within the parking brake release control motor which is connected by a rod to the upper end of the parking brake release vacuum hose (2B653) .
  • The parking brake release vacuum hose which connects the parking brake release control motor to the engine manifold through a vacuum release switch at the steering column tube (3514) .
  • The parking brake release control motor which is actuated to release the parking brake whenever the engine is running and the transmission is in a forward-driving gear.
  • The automatic parking brake control which has a manual release feature that releases the foot parking brake control by applying force to the parking brake control pedal in the "apply" direction to the point of initial application.
  • The parking brake control will return to the full-release position after removing the force.
Apr 14, 2009 | 1994 Lincoln Town Car
Bell Sports Bell Deluxe Patch It Tube Repair Kit Logo
65 people viewed this question
Top Bell Sports Cycling Experts
Tom Chichester
Donald Ayers-Marsh
Are you a Bell Sports Cycling Expert? Answer questions, earn points and help others
