Question about Admiral AW22 Top Load Washer
ADMIRAL 22 WASWHER
I TURN IT ON FILL WITH WATER BUT IT WILL NOT RUN A COMPLETE CYCLE, I HAVE TRIED MANUALLY MOVING THE BUTTON BUT IT WILL NOT DO THE STEPS, COULD IT BE THE TIMER?
  • 639 Answers
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
It could be an electronic problem. better call service!!!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Posted on Aug 28, 2008
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Dishwasher goes thru cycles but does not fully and leave dishes with film
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 20, 2011 | Admiral 24 in. DWUA800AA Built-in...
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
How to get the clean off an ge coffee pot?
To clean the coffee stains there has a magic cleaning tools--magic melamine sponge. Magic sponge just need water and don't need detergent , strongcleaning capacity,saving time ,energy,convenient. The most distinguish with the traditional cleaning sponge is that the magic melamine sponge adopts physical cleaning principle. During cleaning, it can automatically absorb the stains on the surface. It is like countless superstrong mini cleaners working together.
When you use the magic melamine sponge to clean the oils on the dish you just need to follow below steps:
Step 1:put the magic melamine sponge into water,
Step 2:then use the hands gently squeeze the excess water in the magic melamine sponge.
Step 3:using the magic eraser gently wipe the part where has the pen stains
Step 4:after cleaning you can use a dry cloth to wipe up the dirts on the walls
Step 5:finally, you just need to put the magic eraser into clean water, the dirty will be dissolve automatically.
En world sales magic eraser sponge En world dedicated cleaning sponge...
Magic Melamine Sponge
Dec 21, 2008 | GE 106591 Coffee Maker
Washer does not fill with water
One simple thing to do is remove the hoses from the machine and remove the screens. Leave them off or clean them and put them back. The screens will probably be pretty clogged. Replace the hoses . Turn the water on check for leaks and retry.
Dec 18, 2008 | Washing Machines
Admiral Designer Series Super Capacity Washing Machine
This machine will rotate the motor to agitate in one direction and then reverse to activate the pump and the clutch for spin. I would remove the inspection plate and watch the motor and pump in action in both wash and spin, go to www.apdepot.com and dig around you will find parts and a wire schematic on this machine.
Jul 23, 2008 | Admiral AAV7000A
Admiral AW22 Top Load Washer Logo
57 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De GO PATS
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
