Question about Dometic RM2652 Refrigerator
Refrigerator will not cool
Will not work on electric or gas it blu both fuse its been stored for 6month
on gas it will lite but doesnt heat long till it will go off in about 2 minutes it comes back on.any sugesston. thanks billyjo.
  • 51 Answers
Disconnect the electric heating element from the board on the back. Replace fuses see if it will run on gas now. If it will your heating element needs to be replaced.
Posted on Sep 07, 2008
6ya staff
SOURCE:
Domestic 2652 works on gas but will not work on 120vac fuses are good and voltage measured at the supply line on the board is 120vac
While in electric mode the refrigerator heats the ammonia with a heating element that causes the refrigerator to cool inside. Can you test that element?
Appliance 911 Sea Breeze
Sep 01, 2015 | Refrigerators
Dometic refrigerator troubleshooting rm 3662,
Hi, It is more then likely the heating element or a fuse in the electronic board located on the rear of the refrigerator. The heating element is located on the right hand side looking at the rear of the refrigerator. It is the probe like item that protrudes from the duct work with two black wires attached. You must disconnect the wires from the board then take the door off of the duct work, the the heating element will slide upwards to remove it. Please feel free to contact us 1-888-782-6665
ArctiCold Refrigeration We keep it cold
Aug 17, 2014 | Dometic Refrigerators
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Apr 17, 2011 | Dometic RM2652 Refrigerator
What causes a refridgerator to stop cooling and will not cool in ether elecrtric or gas mode of operation? model RM2652, checked and replaced both fuses in control modual. This failed to cool after several...
There has to be a heat source to circulate the ammonia. . If the If the problem started after a power outage I would suspect a problem in problem in one of the control boards or controls. Verify power to the main board and look for voltage to the heating element in electric mode and power to the ignition circuit for gas.
Eric
Aug 11, 2010 | Dometic RM2652 Refrigerator
No heat glow plug doesnt lite
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Whirlpool LGR5636L Gas Dryer
Works great on gas but not on electric
AC electric heating element may be bad. also there should be a fuse for the heating element in the lower control board. Make sure it is unplugged when checking since it is 120 VAC. Hope this helps
May 04, 2009 | Refrigerators
Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
Jun 13, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
222 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
John Tripp
John Tripp
Paul G
Paul G
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
